Results 1 to 3 of 3
Thread: CDTI 150 No Power EGR Valve?
    Regular Member CGSRI's Avatar
    Hertfordshire
    Arrow CDTI 150 No Power EGR Valve?
    I've read all the threads about EGR Valves and think I have the same problem with mine as it has almost no go until about 2250 - 2500rpm.
    This isn't something that has come on slowly that I have noticed but another concern is that the cruise control comes on and then immediately goes off again when engaged?
    I noticed this a couple of weeks ago when on the motorway @ 70mph I engaged cc and almost immediately it turned itself off. It seemed to only be an intermitent problem. Are they related?
    Thanks in advance for any advice.
    Regular Member Fash's Avatar
    Doncaster
    Not usually related. There is a cruise control fix in the "how to's" involving some sticky tape, and the speed thing is likely to be EGR/solenoid and boost sensor related probably.
    Regular Member jrwilshire2003's Avatar
    Bridgend
    Yes its the EGR valve. Mine was exactly the same. Was driving at 75mph with cruise control on and the car shut it off and flagged up the spanner light. The car went into limp mode but only for 10secs then managed to re-engage it. That was the start of things to come. Couple of days later it was going into limp mode all the time. Usually going up a hill. It raised another fault code aswell. Something to do with air leak can't remember the code. New EGR solved all these issues. Good Luck!
  1. 3.0v6 cdti 183BHP 06plate loss of power.EGR valve suspect
    By tonydyett in forum Y & Z30DT Specific
    Last Post: 28th June 2013, 19:34
  2. 2003 1.8 vectra c Brake power boost Valve
    Last Post: 1st November 2012, 21:28
  3. Can u lose power with a dump valve 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 26th July 2011, 19:09
  4. 1.8 petrol 16 valve power increase,s ?
    By clancruiser in forum Petrol Engine related
    Last Post: 13th March 2010, 18:20
  5. Swirl Valve, EGR and no power
    By kryton01 in forum Engine & Drivetrain
    Last Post: 30th September 2008, 06:41
