Thread: EGR problem ?
    Germany
    Default EGR problem ?
    Hi all,
    I have a 2006 Signum 1.9 CDTI automatic (150)
    the last few days when accelerating away it takes a few seconds for any real power to come through. When it does the power seems to be normal
    I think is the EGR that is dirty, but reading other threads people mention that they get a spanner light. I have not seen the spanner light. Any body had a problem with the EGR that did not register ?
    Thanks for any ideas
    Chris
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Yes, you don't always get the spanner light with an EGR fault, its probably sticking. Do you have any other symptoms, slight misfire between 1500-2000rpm, slightly uneven idling etc....??
    All the above would point to the EGR valve probably being in need of a good clean.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    As said you don't always get the spanner light with an EGR fault. My 3.0CDTi for example ran without the spanner light for 5k miles, but it made such a black smokescreen everytime I put my foot down
    Clean the EGR and it should help for a bit.
    Germany
    Thanks guys for your quick answers, think I will buy an new one on the internet, and just replace it. Cost around 100 Euros in Germany
    scotland
    Quote Originally Posted by chrish View Post
    Hi all,
    how to clean egr new method (pictures)
    http://i187.photobucket.com/albums/x...8/SP_A0271.jpg
    obviously locate and remov e egr valve, not difficult at all
    http://i187.photobucket.com/albums/x...8/SP_A0272.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0273.jpg
    just a couple of pictures of valve when removed note the soot build up!
    http://i187.photobucket.com/albums/x...8/SP_A0276.jpg
    seperate the valve by undoing 4xtorx bolts
    http://i187.photobucket.com/albums/x...8/SP_A0277.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0278.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0279.jpg
    look how bad this looks!
    http://i187.photobucket.com/albums/x...8/SP_A0280.jpg
    drill a 3mm hole in top of valve as shown
    http://i187.photobucket.com/albums/x...8/SP_A0281.jpg
    gently tap punch through hole until the solenoid insides come out next pic
    http://i187.photobucket.com/albums/x...8/SP_A0282.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0283.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0284.jpg
    what you should have when you have tapped out insides of solenoid now you will see the real cause for the egr complaint these parts will be corroded and cause sticking, believe it or not its not the soot that jams the valve but this corrosion
    http://i187.photobucket.com/albums/x...8/SP_A0286.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0287.jpg
    http://i187.photobucket.com/albums/x...8/SP_A0288.jpg
    clean up removed solenoid parts, i use a bench wheel, and reassemble in reverse of removal but lubricate all parts with a touch of grease or the like.
    http://i187.photobucket.com/albums/x...8/SP_A0289.jpg
    gently tap solenoid parts back into place until flush
    http://i187.photobucket.com/albums/x...8/SP_A0290.jpg
    you can now depress plunger and notice one hell of a difference. at this point you will have to clean the body of the valve in some form of cleaner.
    http://i187.photobucket.com/albums/x...8/SP_A0291.jpg
    spray some more grease etc into the 3mm hole
    http://i187.photobucket.com/albums/x...8/SP_A0292.jpg
    finally reassemble and refit to vehicle, trust me you will be very impressed with the results.
    Chris
    Hi Chris, I Had the same problem and i took the EGR valve out and cleaned it but it made no difference, the problem became evident when i took the EGR valve solanoid off. It doesnt seem to be the soot thats the problem but the solanoid gets some corrosion on it and it causes the valve to be either stuck open or closed. Google "cleaning a EGR valve properly vectra c" and there are some excellent pics showing the stages of removing the valve and the solanoid, dont worry about stripping out the valve and solanoid it is really quite simple. This solved my problem. I plugged my car into the diagnostics and there were no fault codes at all. Hope this helps.
    Germany
    Maybe a daft question, If I buy a new EGR valve , the solonoid is part of it ? I.E. new a EGR valve includes new solonoid ?
    scotland
    Yes mate it will include the solanoid, but before you buy a new one i would recomend cleaning it first it could save you alot of money.
    Germany
    Deeks, decided to buy a new one. I think its easier knowing my technical skills !
    one question...when i replace it, do i need to disconnect the battery ?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    No. Just don't leave the ignition on
    Germany
    Replaced this morning, and its running like new again ! Thanks for all the advice guys !
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
