Thread: cdc40 Aux in
    Regular Member StephNET's Avatar
    Wiltshire
    Question cdc40 Aux in
    Hi all. I've just put a deposit on a 54 plate Elite cdti150. I know the cdc 40 doesnt support an aux in, but has anyone tried splicing into the signal cables from the dab box? I could see using a 3 pole A/B switch to select between dab or a 3.5mm cable. Has this been tried?
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am assuming by the lack of response that this has not been done...
    You could always try it and report back.
    Alternatively, try the German forums...they have tried most other things with varying degrees of success.
    There's even some stuff posted up on YouTube.
    I would expect however, that if this has been done, then it will have been done with micro-electronic SMD type components being fitted into the main head-unit circuit board.
    Personally, I don't know if this would work, but I would assume that if an audio signal is sent to the head unit from the DAB unit, then this would be in a digital format...so it could be assumed that your audio signal would also need to be in digital format.
    Wiltshire
    I picked up the car this weekend, and I was mistaken, its a CDC40 but no dab tuner/ariel. I've decided to use my kenwood cd player from my pervious car.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I've looked at the wiring pin out for the CDC40, and it is the only radio that can have the Aux In wires fitted - According to Vauxhall's TIS and information of the german Vectra forums, it can be wired in place of the DAB audio signal wires.
    Wiltshire
    Have you got a link to that forum? Do they mention what has to be done with tech2 to enable the feature? I would love to keep the factory unit if possible
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I don't have a link, and I don't believe there is any Tech 2 required.
    But I have seen wiring pin outs from Germany, which state that Aux In can be fitted in place of the DAB audio input..
    I did a translation of it years ago for my CD70...sadly it was no use to me
    Here is a scanned copy..
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. CDC40 Aux In
    By SRiXPT in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2010, 02:09
  3. CDC40 and Aux in??
    By caspy in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2009, 17:06
  4. CDC40 DAB yay or nae?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2009, 16:22
  5. Cdc40 Mp3
    By SJG in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2008, 20:34
