Results 1 to 10 of 19
Thread: vacuum pipe?
    Regular Member tj56's Avatar
    Apr 2008
    Tyne and Wear
    Default vacuum pipe?
    hi all, need help with this please.
    link to problem
    http://www.vectra-c.com/forum/showthread.php?t=103369
    thanks
    rob
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Try another dealer m8 i ordered a complete set of tubing and connectors from my local dealer cost me all in around a tenner
    Apr 2008
    Tyne and Wear
    thanks mate, dont suppose you can recall part number for complete kit by any chance do you?
    Apr 2008
    Tyne and Wear
    just spoke with different dealer and rubber elbows are 4.94 each and pipe is 4.74 per mtr.
    total cost to replace all would be a lot more than a tenner.... am i being jipped here or what by vx?
    Nottinghamshire
    Quote Originally Posted by tj56 View Post
    When I needed some new vacuum pipe, the rubber pipe for the ends was also sold by the metre. I think that you only need to buy pre-cut rubber connectors when they are anything other than short straight pieces i.e. right angles and curves where a straight piece of pipe won't do.
    Apr 2008
    Tyne and Wear
    the ends are elbows mate so would not be able to use the straight rubber tube.
    i thought it would be probably best to replace them as they'd be a nice tight fit with them being new but seems a lot of cash for what they actually are.
    Apr 2008
    Tyne and Wear
    part numbers he gave are
    90572322 (elbow)
    90018280 (pipe)
    dont suppose any of you guys know if these are defo the parts and he's not gave me wrong part numbers, i.e part numbers for wrong/more expensive parts?
    Engine : 2.0DTi
    Mileage : 73350
    90572322 is right for the elbow,s
    can not help with other pipe but how much of it do you need ,
    you probable only need about a foot at most , my dealer asked me how much i needed and ordered as required
    Apr 2008
    Tyne and Wear
    i was thinking about replacing all of it, that way i will be confident there is no pipe left unchecked
    Nottinghamshire
    OK. The rubber connectors that I needed to replace were the straight ones, so I could just buy the 'by the metre' stuff.
    Perhaps you can minimise the cost by checking the pipes and rubber ends yourself to identify any that have got leaks so you can just change the those. That's what I did and ended up only needing to replace 1 vacuum pipe and it's 2 (straight) rubber connectors. It's just like checking ignition advance in the olden days when it was vacuum-operated, only you need to repeat 2 or 3 times depending on if your car has a vacuum-operated valve in the top of the throttle body or not.
  1. vacuum pipe size
    By jonny22 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2012, 13:26
  2. 2.2 DTI vacuum hoses / pipe
    By Alistair123 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 15:50
  3. vacuum pipe
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2011, 16:27
  4. brake vacuum pipe-removal help
    By barney490 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2010, 13:30
vectra c vacuum pipes site:www.vectra-c.com
