Results 1 to 2 of 2
Thread: Knocking rear N/S and tapping brakes - low speed...
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Knocking rear N/S and tapping brakes - low speed...
    Hoping its nothing to do with having it lowered
    Tapping brakes at low speed has been doing it since cleaned them up and painted the calipers, only doing it on the N/S rear... maybe i over did the cleaning? will copper grease fix this, spring clip is on perfect?!?
    Also getting knocking at low speeds when turning left round corners, same N/S rear wheel, and at no other time??
    I was told there is play in my bushes on the rear after fitting springs?!?, O/S rear is squeeking when passengers get in and out of the back... but the knock is from the other side...
    Cheers.
    Also on a different note, mates had all his pads change, but pad wear sensor is still coming up everytime he starts the car, is it just a new sensor needed... is it an easy to replace...
    18 Post(s)
    Mileage : 110k
  1. tapping from rear caliper/brakes
    By bobsimes in forum Vectra C / Signum Troubleshooting
    Last Post: 7th July 2012, 09:17
  2. Knocking Knoise From rear Brakes
    By RikD in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2012, 10:33
  3. Front knocking at low speed???
    By bones341 in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2012, 20:04
  4. Knocking/Tapping Noise
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2011, 16:07
  5. Speed dependant tapping from engine
    Last Post: 3rd August 2010, 20:25
vectra c rear knovking slow speed
vectra c knocking from rear caliper
z19dth rear breaks knocking
