Results 1 to 10 of 27
Thread: Pleeeeeease HELP.....
    Regular Member dawasdave's Avatar
    Norfolk
    Unhappy Pleeeeeease HELP.....
    Hi all, Im a little worried about me car but i dont know weather i should be or not....
    Car is a 57 SRI 2.0t (Z20NET)
    1st thing is i get a little rattle from the engine when my foot is off the clutch but it goes when i press my foot on the clutch, Is this normal for these cars or should i br worried...
    2nd is my lights dim a little when you are at a standstill and you turn the steering wheel left or right, again is this normal of not.....
    Please help as its a new car and warranty is running out fast....
    Dave
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    rattle could be dmf, dimming could be alternator/battery problem, either way i would get it booked into vx for a check up if it's still under warrenty...
    Midlands Mod Shop - NFFC.
    Regular Member vxr-i-wish's Avatar
    Nov 2009
    Quarry Bank, W.mids
    Think the lighting problem is same on all vecs, not sure about the clutch, maybe clutch release bearing or sumthing??
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Cant honestly say that i've noticed any rattles on my 2T...but im sure if i tried i would..
    is your battery/alternastor up to the job???
    Regular Member dlm71's Avatar
    Cheshire
    Mine has the same lighting problem! when it was in VX last for some warranty work i reported it and they said there is no fault code for it and they cant physically find a fault either! A cop out by VX if you ask me, when it's out of warranty i bet they find the fault then! when i have to pay
    I have put it down to the steering pump taking a load from the electrical system!
    I would be interested to see as well if others suffer the same and have a different explanation than VX
    Regular Member azz man's Avatar
    manchster
    Just dropped my 58 2.0t into vx tonight for a new alternator under warranty. Cutting out when air con on and erratic revs while idling. I have also noticed the lights dimming when turning too I will see if the new alt cures this.
    I also noticed the funny rattle when clutch is up. Not told vx bout this as I did not think it to be a big prob, am I wrong? It’s due a service next month I might just mention it then.
    The only other on-going prob is a squeaky driver’s seat arrrhh why can’t they just fix it!!!
    Oct 2009
    Teesside
    Dual Mass Flywheel definately mate, VX charge 1k for the pleasure of changing it as well!
    If its under warranty get it in as soon as possible before your warranty runs out!
    Search DMF and you'll find loads of threads on this very common fault!
    Oct 2009
    Teesside
    Quote Originally Posted by azz man View Post
    I also noticed the funny rattle when clutch is up. Not told vx bout this as I did not think it to be a big prob, am I wrong? Itís due a service next month I might just mention it then.
    The only other on-going prob is a squeaky driverís seat arrrhh why canít they just fix it!!!
    Very big job mate, got to drop the subframe etc!
    Norfolk
    ummmm i think its gonna have to spend the day with vaux then..... I bet they do there usual though and say "theres nothing wrong with it".... Grrrrrrrrr
    Norfolk
    Oh and she has only done 20k
