Thread: Clunks when starting
    Regular Member mishima's Avatar
    UK
    Question Clunks when starting
    Hi there,
    Just recently I've noticed this as being a problem, its got notably worse. When I startup and use the clutch to edge forward or even just use clutch control to start off I get this clunking racket of a noise occuring. It sounds quite worrying.
    I have a 52 plate Vectra C. 2 Lite DTI.
    Does anyone have any indication of what this may be?
    West
    I had a problem similar just after the a garage changed the outer cv joint, the hub nut had not been tightened up correctly... once i nipped the nut up a bit more the clunk dissapeared.
    hth
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    dh.dti could be correct, do you also get a knocking when on full lock one way or the other? If so I would suspect the cv joints.
    UK
    Guys I just pulled up to a friends and when turning the engine off had the usual rattle and clunk so I jumped out and had a look underneath. This is what I saw:
    A panel seems to have come loose, the bolts must have rotted and fallen out...
    West
    That's a heat shield matey, you have 2 options remove it completely or get underneath & refit using large washers.
    UK
    Does it protect anything??
  1. clunks and pings
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 16:37
  2. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
  3. Clunks from rear of car
    By Angelchops in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 11:08
  4. Suspension 'Clunks'
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 15:17
  5. Suspension 'clunks' when cold. Anyone got any knowledge.
    By andrewp3883 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2007, 23:30
