Thread: due a change
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default due a change
    i need to do an oil change on my 2,0dti. nation tyres want £45, but i was thinking about doing it my self because i can do a basic service for that much with filters, ive done old changes before but that was on the vectra B how hard/easy is it????? is it a case of taking the under trays off and sump plugs there???? also jut checking on euro car parts the filter for oil dont look like a srew on filter are they diff on the vectra c?
    what size is sump plug?
    Edinburgh
    I had an Astra 2.0DTi so hopefully the Vec is the same. The filter was a paper filter that was just insert into the enclosure. The enclosure was accessed from above at the front of the engine with a 34mm or 36mm socket.
    Like you say, engine tray off, sump plug is located on the sump. On my 2.0DTi is was a torx key needed to remove it (careful not to strip it). I also replaced the sump plug when I serviced it.
    Oct 2009
    Sandwell
    ive gone with nation tyres to change it ill pay the extra becaue if they bulls it up they can sort it, i also need to reset the service indecator ill search for that tho lol
    anybody know how to change deisel filter my brother-in-law is gonna do it tomorrow but hes one of these he says he can do it but will end up braking somat
    Edinburgh
    Diesel filter on my 2.0DTi Astra, the filter housing is at the rear of the engine compartment. I just opened it using a torx key, changed the filter and the seals and closed it up again. Some people top up the enclosure with diesel but I didn't bother. Just spent a few moments stuttering until the fuel came through and then it started fine.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
