Thread: 6th gear
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default 6th gear
    just bought a sri with 6 gears, never driven a car with 6 gears little bit of gitting used to, what speed should you reach to change to six, short journeys stopping starting never get in six, any tips.
    Leicester
    Its a hard one to answer, use it like you would 5th in a 5 speed car.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    In my 6 speed Auto it very rarely goes into 6th until abount 63/65 MPH in Automatic mode.
    I drive as per normal, up to 6th gear, with no more than 2000 rpm in each gear
    Typically I reach 6th gearby 50mph
    However, if you use the instant MPG you will notice that 5th gear can sometimes be more efficient than 6th gear, especially when driving on NSL country roads
    Equally, to overtake 6th to 4th gear or even 3rd gear can feel like you are "stirring the pot"
    Finally, if you want to "go fast", then don't use 6th gear, as your can actually go faster in 5th gear
    As above, just follow the engine revs. If they're getting close to 2000rpm and you're crusing, then change up. If you're trying to overtake then change down till you're sitting at about 2500rpm then put the pedal to the metal...
    You'll get used to it after a while, but as mentioned if you're doing cross country stuff at about 50mph then fifth can be better as you'll have more torque to play with when trying to speed up...
    Regular Member Marcosuk's Avatar
    Fife
    Have to agree with the above... 6th only get used on the M/ways for me..
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    i only use 6th on motorways or dual carrigeways
    Quote Originally Posted by neverlandandy View Post
    I normally use 4th gear at 30mph, above this I miss out 5th gear and go straight to 6th gear
    Driving at 35mph in 6th gear does seem unusual, the 3.0 V6 CDTI copes very well with it, but don't expect any from of acceleration until you get to about 45mph
    Regular Member barkzz's Avatar
    I generally put it into 6th around 40-50mph well in "economy" Style.
    Other than that my right foot dictates!
    Mar 2007
    Beaconsfield, Bucks
    dont get into too high a gear too early or you will lose all engine braking effect
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
