Results 1 to 10 of 19
Thread: map lights
    Edinburgh
    Default map lights
    Mine have stopped working. Just wondering, are they fed from the rear fuse box in the boot?
    Regular Member killer_bunny's Avatar
    Jan 2010
    leeds
    have you changed the bulbs?
    Edinburgh
    sorry, I probably should have been clearer, all the bulbs have stopped working including the ones inside the buttons that should light up when the headlights are on. So unless they all popped at the same time (unlikely) I'm guessing its not the bulbs
    Jan 2010
    leeds
    could just be the connecter is loose, take the glass like panel off the console and the other covers. next to the bulbs there will be 3 torx screws, unscrew these then the whole console will unclip from the roof. there is a block connector, just unplug it and plug it back in as could of worked its way loose. only takes 5mins then if it isnt that just check all the fuses
    Edinburgh
    whats worrying me is, I had the roof lining down to see about wiring in a rear interior light and there appear to be 2 ribbon cables that go over the roof and one of them has seperated, looks like they are only taped together at the pillar which seems a strange was of connecting electric connections however I have retaped them with no luck
    Jan 2010
    leeds
    one of those ribbon strips goes to front, not sure about back!
    Edinburgh
    hmmmmm, the sensors for the alarm seem to work but not the lights. confused now.
    It looks like a wide ribbon comes out the light unit, goes towards the passenger door and then goes towards the rear passenger side. i think it then splits into two thinner ribbons. I've reconnected both now but still no lights :s
    Edinburgh
    damn, just realised there isn't meant to be a break in the ribbon cable. looks like I need a new roof loom. Any ideas on cost & part no. folks?
    Jan 2010
    leeds
    wont be cheap me thinks! best going to scrappers
    Edinburgh
    From OilBurner's HowTo, looks like the harness is about £50.
    The part number quoted is 13116730 from a MY2004 car. I have a Facelift 2006, anyone know if a pre-facelift roof loom will fit a facelift Veccy ok?
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
