Thread: engine revved to max 150 cdti
    Co.Antrim
    Default engine revved to max 150 cdti
    Hi
    My engine suddenly revved to max !Would not stop with key so i choked it in gear to stop it! Got it home and checked oil level which was very high on dipstick so there must of been diesel in it. I changed the oil and started it up with no problems and now it fills the road with white smoke but is going well. Any ideas ? Injectors have been tested and were 100%
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    oil may have found its way into the combustion chamber.
    Gazza4
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Its a guess but could it be the turbo leaking oil into the inlet?
    Jul 2009
    county down
    i'd keep it off road until u find out what's goin on to ensure u don't wreck engine!
    could be cylinder head (white smoke? could this be steam? did u test coolant?) engine reving out is weird though cuz that sounds like an electrical issue. Car should be 'limp mode' if there is a water/oil compression issue. keep us posted.
    EVERYWHERE
    It is critical that the oil level is not above maximum on diesel engines. Any excess will be find its way into the engine combustion process and cause 'runaway'. You may also have damaged the cat/DPF.
    Jan 2010
    preton
    Quote Originally Posted by diesel dog View Post
    just a thought how would you stop a auto in this situation
    Regular Member cbl1985's Avatar
    warrington cheshire
    it could be a number of things
    1. head gasket
    2. stem seals
    3. turbo gone
    4. or the oil has got into the exhaust from to much oil and when it gets hot buring the oil in the exhaust
    Co.Antrim
    Stripped down today to find the turbo has gone and oil has been sucked back through the inlet!
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. The 1.7 CDTI engine?
    By Leemarksmith in forum General Motoring Chat
    Last Post: 10th November 2012, 22:19
  3. Best engine oil for CDTI 150 ?
    By aps in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:02
  4. Hi, 1.9 CDTi, which engine?
    By Craigus in forum Introduce yourself.
    Last Post: 1st January 2010, 11:09
  5. is the 3.0 cdti engine the best one?
    By pogo in forum Engine & Drivetrain
    Last Post: 28th August 2008, 01:00
