Thread: Seat belt guide loose
    Sep 2009
    Glasgow
    Default Seat belt guide loose
    Have a rattle/vibration from nearside rear on investigating noticed that where the seatbelt goes on the nearside rear seats there is a plastic guide that stops the belt rubbing on the seat and that is what is loose, managed to get it off and having a look at it it has clips on it that clip into shaped metal rods within the seat it also had a metal ring on the plastic underside , well it did, it fell off and went behind the gap in the seat , putting it back on I cannot get it on firmly, if i try and move the offside one it wont move but the slightest touch on the nearside one and it moves Also a part number would be great as I think the metal ring that fell off it probably has something to do with the slackness.
    Sep 2009
    Glasgow
    The part circled in red is the offending part. Any takers.
    Sep 2009
    Glasgow
    no one ever removed back seats
    Nottinghamshire
    Quote Originally Posted by nokiaman1978 View Post
    Yes, but last year so memory hazy. The metal ring is all there is that holds the plastic top part to the metal frame underneath, if I remember so it will be rattly and loose it that's come off.
    I tighted the rings up while the seats were out of the car because the plastic bits were coming a bit loose - by tweaking the metal rings tight with a pair of pliers.
    If you still have the metal ring, put it back on (refer to the other side of the back seat to see how it fits) and tweak it tight, or make your own metal ring from an paperclip or something and again fit it back nice and tightly.
    I don't know if dealers would do the metal rings seperately, or if you would have to get them with the plastic covers - or maybe even the whole end-section of the seat.
    Sep 2009
    Glasgow
    thanks for the info , will try tonight.
  1. Replace V-Ribbed Belt guide
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 13:03
  2. Aux Belt Tensioner and guide/pully
    By mikeq in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 10:43
  3. loose aux belt 2.2
    By heheshamon in forum Engine & Drivetrain
    Last Post: 11th November 2010, 13:33
  4. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  5. seat belt light and seat occupancy recognition
    By xc600 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 20:26
vectra c loose back seats site:www.vectra-c.com
