Thread: Gearbox/clutch/brake fluid change-TOMORROW!!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Gearbox/clutch/brake fluid change-TOMORROW!!
    Hi all,I've just decided to do a fluid change tomorrow and wanted clarity to a few questions...
    I've 'saved' the how to's for cluch n gearbox on the site BUT as my cars a 2t is the job bthe same as for the cdti???
    And with the brakes...anyone know the correct sequence of bleeding them??..I normally do opposite corners...
    ANY help appreciated..
    Bristol
    Vehicle : CDTI 150
    Brakes are all the same, use DOT 4 standard fluid.
    I always use an old turkey baster (like a big syreinge) to remove brake fluid from the resevoir before adding fresh fluid then bleed.
    Left rear then right front, right rear left front last.
    Do not use an Ezibleed or similar for the clutch (ok for brakes) you need the old 2 person method (open bleed nipple, foot to the floor, close bleed nipple etc) this is due to the CSC.
    Total system capacity is 500ml.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Are you meaning left as in drivers side?..and why not use an easi bleed for the clutch as in the 'how 2'?..confused am I..
    Bristol
    Vehicle : CDTI 150
    Sorry left passenger side.
    The Vec c has a concentric slave cylinder, you need to actuate the clutch to bleed properly.
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. Gearbox fluid change
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 19:24
  3. Brake and clutch fluid change questions.
    By James24 in forum Handling & Braking
    Last Post: 9th June 2009, 15:15
