Results 1 to 10 of 25
Thread: lnSP code ?
    Regular Member nigec's Avatar
    barnsley
    Default lnSP code ?
    Hi guys as above, i get this code every time i start the car and when i turn off ignition, it shows where the mileage counter is for about two seconds then reverts back to the mileage counter. I presume its something as i carnt recall seeing it before.
    Any ideas ?
    Bristol
    Vehicle : CDTI 150
    Basically its telling you that it needs a service (INSPection) this gets flagged with cars set for the Ecoflex servicing.
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    does anyone no the code to turn it off as i service my car myself
    barnsley
    already had it serviced end of last year, ill have to ask him if he can turn the light off, is it an easy fix ?
    Regular Member mickg's Avatar
    High Wycombe
    press clutch turn the key to the half and pull(press) that little button on the dashboard next to mileage counter for about ten seconds and servicing counter should reset it self... well that what happened in my car... worth trying
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Check a post in this thread from earlier to day.....I'm also sure 'Search' will find something for you...cheers
    http://www.vectra-c.com/forum/showthread.php?t=103174
    Jan 2010
    Wolves
    nice one mate i will give it a go
    barnsley
    Quote Originally Posted by mickg View Post
    Nope just tried it.
    High Wycombe
    hmm... sorry to hear that... keep trying m8 good luck
    barnsley
    Cheers for the tip anyway.
  1. help with code
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 13:43
  2. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  3. lnsp on the dash ..?
    By signum driver in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2011, 00:20
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. code Key
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 15:09
ln5p vectra
