Results 1 to 10 of 19
Thread: bought a vectra !!
    Jan 2010
    kent
    Default bought a vectra !!
    at long last i have sold the lexus and yesterday bought a vectra
    its the 2.2 petrol sri in silver 52 plate and i must say im liking it so far it has 1 or 2 little problems like passanger window switch playing up and cruse control only working if the clutch is pulled up a little !
    i do have a question the rear exhaust pipe is very corroded and looks horrible but i thought the sri had the chrome trim on them ?
    can this be bought seperatly ?
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Trim only comes with the back box on those
    Regular Member johnny1983's Avatar
    Ryton, Gateshead
    Welcome to the site mate
    it could be that the previous owner has replaced the original with a cheaper back box? you do see a few with plain pipes on them.
    Not suprised people do this, as a vauxhall backbox is £200+
    Mileage : 000
    Welcome to the site. The cruise control, sounds like you need a new/replacement return spring on the clutch pedel.
    Jan 2010
    kent
    cool il look in to the spring on the clutch pedel is that something i can replace or need a garage to do it ?
    ive seen a few sri exhausts on ebay so maybe its 1 of them then
    Mileage : 000
    Quote Originally Posted by vxastra View Post
    I have not replaced the spring myself. But I think if you are good with spanners you should be able to do it. Several members on here have changed theirs themselves though.
    Regular Member old cruiser's Avatar
    slough
    It's not too bad to change the clutch return spring at all really and the passenger switch should pop out easily enough and if you're careful you can as I did, take it apart and with some switch cleaner give the rubber key pad and board a clean and all should well with it , incidently with the clutch spring, some I believe managed to crawl under there and change it without removing lower trim etc, I couldn't as I'm a fat *******, so had to remove it, but even so doesn't take long to do it.
    Cheers Pete
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    slough
    Smile clutch spring
    take it into the stealers i think you will find theres a call back on the clutch return spring......
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by AndyFoz83 View Post
    welcome alone mate but as above
  1. bought my vectra but need some help
    By daz263 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 22:29
  2. Has any one on here bought my old vectra????
    By axelf in forum The 'Off Topic' room
    Last Post: 18th July 2011, 10:28
  3. Just bought my first Vectra 2.8T V6
    By driver125 in forum Introduce yourself.
    Last Post: 13th September 2010, 22:59
  4. Just bought a vectra C :)
    By antowns in forum Introduce yourself.
    Last Post: 23rd November 2009, 21:09
  5. just bought my new vectra
    By seagrave in forum Introduce yourself.
    Last Post: 24th January 2009, 18:54
