Thread: Which brake pads for 314mm upgrade, Advice please.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Default Which brake pads for 314mm upgrade, Advice please.
    I have had my 314mm upgrade brakes from LMF on the car for about a year now and checking the pads they will need replacing soon, went to eurocar parts and they did not know which pads to supply because they are not OEM and they require chassis numbers to supply the correct ones!!!.
    Can someone help please.
    So far I have done some searching and think it may be these:
    http://www.brakeworld.co.uk/brakewor...tml/bw4119.htm
    Can someone please confirm if this is correct or not.
    Also suggestions for make etc to replace with, my rotors are 12 grooved and will be good enough for one more set of pads before I need to replace rotors and pads together.
    Thanks.
    Regular Member Jezzy's Avatar
    S.E
    Go to www.Autotrader.co.uk , do a search for 2.8 V6 engined Vectras or Signums (not the VXR), pick one from the list, enter the reg number of that car into the Euro Car Parts website. That will bring up the 314 brakes.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    speak to Danboy........he works at lmf and very helpfull
    Jul 2006
    Wolverhampton
    Or These
    http://www.brakeworld.co.uk/brakewor...html/bw985.htm
    Both are listed as 314mm
    Jul 2006
    Wolverhampton
    Anyone bought a kit and yet to fit it?, any chance you can have a look at what's in the box please.
    Leicester
    Put in Vauxhall OEM pads, they are probably one of the best to buy for a road car.
    314mm fronts - 93176379
    Or the disc and pad kit is only about 80 quid from VX: 93186299
    Jul 2006
    Wolverhampton
    Thanks Penfold, the number gave me a link to police spec pads which is what I will be ordering.
    Jul 2006
    Wolverhampton
    For anyone else
    I have found this cross reference.
    http://www.comline.uk.com/comline/bulletin/adb01593.pdf
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. LMF 314mm Brake Upgrade...
    By vauxhall4life in forum Handling & Braking
    Last Post: 22nd February 2008, 17:49
  3. 314mm brake pads for GSi...
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 15:26
