Thread: what hoses could be spilt on cdti
    newcastle
    Default what hoses could be spilt on cdti
    i have a p0111 code on car have cleaned maf sensor gonna clean egr but could hoses be split on it and where do i look need this sorted not paying vx money
    Bristol
    Vehicle : CDTI 150
    Check hose from MAF to turbo, then turbo to throttle body.
    Any of the pipes from the Vacuum pump through teir solenoid valves to the respective diaphragm,
    Hose to the turbo
    newcastle
    which 1s r these as im complete engine novice
    Bristol
    Vehicle : CDTI 150
    Big trunk from your air filter box which goes from left to right and down to the turbo.
    throttle body is at the rear passenger side of the engine, there is a large trunk that comes up from the turbo.
    Vacuum pump sits at the front right hand (pax) side of the engine, there are a number of thin Vac pipes that come from this. The solenoid valves have two thin pipes and 1 elect connector.
  1. 1.9 CDTi (120) Silicone Boost hoses
    By awsri4 in forum Diesel Engine related
    Last Post: 7th July 2014, 09:24
  2. CDTI 16v silicone hoses
    By husky in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 11:32
  3. 1.9 CDTi silicone boost hoses
    Last Post: 12th February 2011, 14:35
