Thread: egr on cdti
    newcastle
    Default egr on cdti
    where is it located on cdti wanna clean it cos my runs rubbish at min got a p0111 code
    Regular Member P3tchy's Avatar
    Milton Keynes
    Back of the engine, 2 x 13mm bolts for the down pipe (dont drop the gasket) 4x 10mm bolts into the inlet manifold (dont drop the gasket) This is assuming its a 150cdti
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    newcastle
    think i have found it it is at top what screws do i take out to get it out
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    what have you 120/150 ?, have you done the job yet?.
    newcastle
    150 no not yet working up 2 it
    newcastle
    ok found erg i took out the 4 nuts on side thut could not undo to on top as they were solid managed to look inbetween how you detach the power lead into the erg valve
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    the plug should have a little yellow clip slide that down then press the plug and detach its the same type of plug all over the engine so have a look at them its a case of unlocking the collar then pressing the actual plug while gently pulling
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
