Results 1 to 10 of 11
Thread: Timing Belt 3.0 V6 Diesel
    Gwent
    Default Timing Belt 3.0 V6 Diesel
    Hi all
    Does anyone know how much it should cost to replace my timing belt 06/56 Elite 3.0 V6
    You would be best phoning and getting some quotes, also ask if they have done any in the last twelve months, and if so how many
    My dealership quoted the labour was 6 hours, as they had never done one before, taking the total cost to just under £500
    However, on completion they managed it in just under 4 hours, but they still invoiced VX for the full price!
    On completion, check the air box is remounted correctly
    There is a water drain pipe that runs from the bottom and has to be disconnected
    If it is not reconnected the pipe can become loose, and the whole assembly needs to come out in order to reconnect it
    Finally, ask for the old cambelt back, it should also come with a tensioner and two rollers
    Gwent
    Cheers m8
    autodata book states 1.2 hours for this job
    i got quoted £75 plus parts
    France
    In May last year I was quoted £360 incl parts (belt kit) and VAT by a Vx dealer. When I took it in they then told me this did not include the rollers which turned out to be another £110. They said they had intended to check them and only change if necessary, but I wanted them done.
    Full Member Penfold101's Avatar
    Interesting point to note - V6 CDTi cambelt is driven by the fuel pump and goes nowhere near the crankshaft...
    Quote Originally Posted by littlejohn View Post
    It depends on if you ask for just the cambelt or the kit
    A decent dealership will apply the kit (cambelt, two rollers, one tensioner) without asking, but always check
    Regular Member robster23's Avatar
    Hastings
    Got mine done by a VX mechanic for 300 notes all in with genuine VX parts end of last year. Stealer wanted 350 all in.
    It's easier than the 1.9 for some reason.
    hth
    Quote Originally Posted by robster23 View Post
    Quote Originally Posted by Penfold101 View Post
    It just runs around the top of the 2 heads and down a bit to the fuel pump in the middle of the V - the pump itself and the water pump are driven by a load of gears from the crankshaft...
    It certainly looks easier than some I have seen
    There are no covers to remove, just the air box to remove to give better access
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing Belt
    By L33AVN in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 09:33
  3. Timing belt
    By don1966 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2012, 18:55
  4. Timing Belt
    By Jockweiler in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 13:18
  5. timing belt kit
    By Rapala in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2008, 15:09
2005 vectra v6 diesel timing belt
vectra v6 diesel timing belt installation costs
