Results 1 to 10 of 15
Thread: Sump drain plug?
    Regular Member Paulmac07's Avatar
    Jan 2006
    Livingston (W Lothian)
    Default Sump drain plug?
    On a 1.8 (03) Vectra, where is it??
    Got my new oil and filter yesterday, grabbed my tools, then spent 10mins searching for the elusive drain plug........nightmare. Just hope none of the neighbours saw me....
    [Ex]Admin Duncan's Avatar
    Have a look at this thread. You'll see the drain plug on a 2.0T - yours may be in the same area? That pic was taken looking towards the front of the car.
    HTH
    Jan 2006
    Cheers Duncan, I just found that thread myself. I'm so used to the plug being at the bottom/front of the sump, I didn't think to look at the side/rear......
    Thanks again,
    Paul
    Regular Member Harry's Avatar
    Uxbridge, London
    Are the oil filters meant to come with the plastic cover?!? when i bought mine all i got was the paper filter itself and a few o-rings. Maybe if i got the plastic bit aswell i would'nt have felt so ripped off for spending 30 quid.
    Regular Member Geoshaw's Avatar
    Armadale (West Lothian)
    Quote Originally Posted by Harry
    I never got the plastic bit either harry, I've never seen them come with this.
    Uxbridge, London
    well that's alright then, as long as its not just me!
    What you see in that photo is exactly what I got when I bought an oil filter for mine. Are you guys meaning the plastic bit at the bottom with the nut/o-ring etc.? Maybe on the 3.0CDTi you need to reuse the one that's on the original filter?
    Yes thats the bit, it doesn't come with that for the isuzu engine, just the element and o-rings.
    The Blackburn End
    As it is easy to change the filter, I would recommend that you change it often, say 6 months or 6K. I'd never run one for 20K, your asking for trouble.
    Who mentioned that they were keeping it in for 20k?
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. dti sump drain location
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 22nd February 2011, 21:46
  3. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
  4. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
  5. Sump Drain Bolt
    By Dazzar in forum Engine & Drivetrain
    Last Post: 4th January 2007, 09:51
