Thread: knocking noise
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default knocking noise
    hi guys i have a knocking noise sounds quite loud only happens now and then going over bumps or speedhumps sounds as if cumming from the drivers side front wheel
    i had the wheel off today and jacked up checked the spring and ll is well checked the long thin bar that goes from top of strut to i link at the bottom i take it this is the anti roll bar??? all is tight and no play in bushes i have checked the front subframe and everything i can see which connects and all is fine nd tight no play at all and cant see anything obvious broken any ideas guys thanks
    kings lynn, norfolk
    *bump*
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    ARB bushes lots of thread on them. Just wait to the warmer weather noise disappears then...
    somerset
    mine went into the garage for the same problem, and he said there is so little play in some of the bushes that you can barely feel the problem, But the knocking is when the bushes find a new position, which is why it only happens every so often.
    kings lynn, norfolk
    ok cheers guys i though the shock was sticking lol
    so there is no worry and you reccomend just leaving them the car handles like a dream at the moment so i think i will leave as long as it causes no damage
  1. knocking noise
    By 150cdi in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 19:20
  2. help with me knocking noise please....
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2010, 21:00
  3. Knocking noise...
    By Gripper in forum General Chat
    Last Post: 9th September 2009, 08:12
  4. knocking noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2008, 18:16
  5. Knocking Noise?
    By akeem in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2008, 19:17
