Results 1 to 3 of 3
Thread: Crunching
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default Crunching
    I've seen a couple threads on this but would like some comments.
    Whenever i go over a hump something crunches on the front end. It usual goes after the car is warmed up.
    I seen that this could be either the bushes or the rad mounts. Is it more likely to be one than the other?
    Car is a 2.0 DTI 52 plate
    Also the rear suspension knocks - are there drop links on the rear as well??
    Ben
    Regular Member Jezzy's Avatar
    S.E
    Yes, there are drop links on the rear as well, stubby ones.
    As for the crunching noise at the front, could be either of the possbilities you've mentioned, but if you fit the ARB bushes yourself, it'll only cost you about £5-8 to buy them, so it's worth starting with those to see if that gets rid of the noise.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    They're a right ball ache to fit though, it's a pretty straight forward job just tight for space!
  1. gears crunching
    By melvin in forum Engine & Drivetrain
    Last Post: 27th April 2012, 18:39
  2. Little crunching getting in second gear sometimes
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 09:36
  3. Crunching Noise
    By Decker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 01:31
  4. Crunching gears from 2nd to 4th
    By FinestJammy1 in forum Engine & Drivetrain
    Last Post: 28th August 2008, 15:41
  5. Crunching gears from 2nd to 4th
    Last Post: 28th August 2008, 11:29
