Results 1 to 10 of 16
Thread: timing belt change
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default timing belt change
    hi folks, had a search but cant seem to find my answer.
    can someone tell me when i should be looking to change the timing belt on my veccy.
    its a 54 plate 1.9cdti 120 with about 72500 on the clock.
    cheers in advance
    Mileage : 55000
    I would recomend changing the belt and pullies, also the water pump every 40,000 miles. If yours has not been done yet then I would say it is over due.
    Ive just had a look at the service plan for the Z19 DT and the Z19 DTH engines and Vauxhall say 10 years or 100,000 miles for the timing belt. It would probably be better for you to phone your local dealer and get that confirmed though.
    Ireland
    VX say 100K/10yrs. Which seems very long to me but I guess a lot will depend on how its driven.
    A friend of mine has just run his 120 to 99.5K before doing the belt/rollers and left the water pump but I`ll probably do my 150 auto belt/rollers at 50K and water pump/belt/rollers at 100K.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    yes its right every ten year or 100,000 miles have to agree with ed taylor would do every 40 thousand and recomend waterpump as well i've seen a few at workk with 30 to 50 thousand miles on where waterpump seized damaging rockers and ends up costing alot.if i was you i would get it done ..
    Mileage : 55000
    If my memory is still correct. VX said the cambelt for the V6 3.2 was 80.000miles. But due to "other reasons" (my discaimer) they reduced it to their original 40.000miles.
    I would recomend in any situation to "err" on the side of caution.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    The Z19DTH is every 10 years or 90,000 miles. Read the service book.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    I would get it done now. The CDTI [150] used to be 100k or 5 years, that was then dropped down to 80k or 4 years and I heard/read a couple of years ago it was lowered again.
    Although the service book tells you, if vx have lowered the interval you wont know unless you get it serviced fully at a dealer.
    I always air on the side of caution and get it done at 75% of the recommended interval. Remember if that belt lets go its a possible engine rebuild.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Mileage : 55000
    You could always phone the local VX dealer. He will put you right when it should be changed.
    May 2011
    Ilkley
    Exclamation
    Just had my 1.8 SRi Nav ( 06 ) 50,000 mls in for full service and advisory for cambelt kit was every 4 years or every 40,000 - And expect to pay £230+ at the stealers.
    Safe to say ill be ringing round for a few quotes.
  1. Help :( low mpg after timing belt change
    By tipsy in forum Engine & Drivetrain
    Last Post: 12th May 2012, 19:02
  2. Timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 18th April 2012, 11:15
  3. Gsi timing belt change
    Last Post: 1st February 2012, 13:30
  4. timing belt change
    By sri matt in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 18:25
  5. when to change the timing belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 12:42
