Results 1 to 10 of 27
Thread: when driving will this damage anything????
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    Default when driving will this damage anything????
    Need some advice again when i drive i use all my gears i get into 5th and 6th as fast as i can (i was told this saves fuel) i dont change when my car begins to judder also when im say in 5th and coming to a junction i coast the car until im nerly stoped then change into the appropriate gear in other words if im in the wrong gear when i change down my car does not rev stupide as am coasting is this ok and can it harm anything
    hope this makes sense
    thanks again
    Full Member Big Sig's Avatar
    Coasting when not in gear uses more fuel than staying in gear.
    If you feel the car juddering it cannot be good imo. It must strain something as its struggling to keep going. Change down accordingly and use engine braking to slow you - this will help to save wear on the brakes too.
    Sep 2009
    coasting isnt the best of moves it does affect the braking and in the event of emergency braking it will just lock up the wheels and you stand more chance of skidding, where as if you was in a gear, they help to slow the car down aswell the brakes.
    in regards to going to the 5th 6th gear quickly doesnt save fuel. if your in the wrong gear your put strain on the engine..... even if your look at the manufacture hand book you will find a eco drive guide.... you should find something like doing 40 or 50mph you should be in 4th or 5th gear, because of how the gear ratios are set at thoses revs the ecu will be programed to supply less fuel to the engine but still have enough power to make you move when you push the pedal.
    Mileage : 000
    Letting the engine "labour" does more damage than over reving it.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Replacing an engine &/or gearbox will cost more than a bit of fuel, even if you do manage to save some.
    Jan 2010
    northumberland
    so its best to slow down on your gears than coast i just thought when slowing down on gears the car revs ect i will use my gears more then lol
    yes the engine rev's as its a grar ratio change, however its not using any fuel at this point.
    Worcs/Staffs/Westmids (ish)
    Don't labour your engine, I posted some time ago about a friends mom who blew up her new Focus by driving round a bent in 5th gear labouring the engine.
    You REALLY don't want to do this.
    Also driving anywhere outside the torque band is highly inefficient, peak torque is where the engine is making the most efficient use of fuel.
    If your really so intent on saving fuel, turn off the AC, use the cruise control when possible, don't open the windows (wrecks aerodynamics), keep your tyres at the correct pressure, service the car regularly, keep the air filter clean, don't carry passengers, don't carry anything you don't need, don't eat so many pies.
    and avoid short journey's at all costs.
    If however any of us see you driving at night with no lights or just parking lights (which doesn't affect fuel consumption)... We will kill you!
    Jan 2010
    northumberland
    Quote Originally Posted by Birchy63 View Post
    ha ha birchy like it lol
    Jan 2010
    northumberland
    i just thought i would save the engine and fuel as i thought when you coast your in effect not not engaging the engine there for no strain
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. Replies: 2
    Last Post: 28th July 2011, 13:37
  3. limp mode on motorway driving.....driving me crazy!
    By big rich in forum Diesel Engine related
    Last Post: 27th August 2010, 05:24
  4. AA driving school car + dangerous driving: Who to report to?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 18:05
  5. Damage to my car :(
    By Martyn21 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2006, 11:45
