Results 1 to 10 of 25
Thread: Automatic locking
    N E Somerset
    Default Automatic locking
    Here's something I noticed tonight and would like confirmation that this is normal on my type of car 2005 my SRi 2.2 direct.
    If I unlock the car fully and leave it for about 30 secs without doing anything else it relocks itself as if I had pressed the r/c lock button once.
    Is this a normal feature?
    Yep.... just in case you unlock it by mistake when you put your keys in your pocket.
    Regular Member VectraMat's Avatar
    Hull
    Yep, standard security feature matey. It will relock unless you open a door, its incase you accidently press the key button while close to the car or unlock your car and then your distracted and forget to lock again.
    My old 51 reg clio did the same thing, and i think quite a few cars do it now.
    Hope this helps bud!
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I just found this out too....cool little feature....
    N E Somerset
    Thanks all for the replies. Good feature once you know but I was wondering if madeness might be setting in at one time. Is it mentioned in the handbook (must admit I haven't read it in full)?
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    yeah its a std feature also on our corsa sri
    wot we also have on the corsa is if i pull the headlamp flasher switch
    towards me and hold it for about 4 sec`s then let go the headlamps keep
    lit for about 30 seconds then goes out,thats for if you live were there is no
    street lighting or on ya driveway,think its a good feature to have so check
    ya vectra`s and test it to see if you have it.
    N E Somerset
    cheers m8, will do and report back.
    Dec 2005
    In the sponge-monkey tent
    Quote Originally Posted by ANDYVEC
    Standard feature on all Vectras I believe, certainly on older models, not sure if it survived the gadget cull on the later models.
    Melbourne, Australia
    Quote Originally Posted by Spikey©
    I imagine they wouldn't take this feature out because it's just a software feature - no ongoing parts costs.
    Vectra's have this too Andy. Also reversing lights come on for those that reverse onto their driveways.
    MkII Cav's had this feature too. If you turned off the engine and removed the key, then switched off your headlights they stayed on for 30 secs.
  1. Automatic locking.
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2011, 01:33
  2. Automatic Box
    By WeDesign in forum Engine & Drivetrain
    Last Post: 9th March 2009, 16:07
  3. Automatic Door Locking
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2007, 20:32
  4. Automatic Locking
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2006, 20:16
  5. Automatic locking?
    By nellsey in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2006, 17:33
