Thread: Gsi coolant loss
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default Gsi coolant loss
    need some advice guys, Had the low coolant level warning light flash up on my dash today topped it up with a mix of antifreeze and water and all seems to be fine had it up on a ramp checking for leaks...is it normal for the gsi's to lose water or am i dealing with something a little more serious??
    Nov 2009
    Luton
    mine leaks it where the coolant hose from the tank to the block is, below the ECU, you might be able to see it drip down the side of the head and onto the bell housing, the o-ring is 2 quid but add 100 if you want vauxhall to fit it
    Sep 2009
    luton
    Mileage : 100000
    is it anything to worry about??
    Regular Member robster23's Avatar
    Hastings
    My coolant sensor dislikes the cold. It seems to flick up when cold starting in sub zero temps but once warm is fine. Levels all ok. Could that be your problem?
    Sep 2009
    luton
    Mileage : 100000
    when i checked the coolant level when the sign flashed up on my dash it was quiet low, since ive topped it up ive had no losses. so it seems to be fine
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    i had a tiny leak would lose half a pint in a month just added a lil rad weld never had a prob with leaks since
    Just keep an eye on it
  1. Coolant loss.
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 10th January 2013, 21:18
  2. V6 Coolant loss, Help!
    By v6boy in forum Vectra C / Signum Troubleshooting
    Last Post: 12th September 2010, 16:01
  3. Coolant loss
    By monkeyhinger in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 23:42
  4. Coolant Loss
    By george in forum Engine & Drivetrain
    Last Post: 12th April 2007, 06:39
  5. 1.8 coolant + oil loss
    By Aleco in forum Engine & Drivetrain
    Last Post: 15th March 2007, 21:52
