Results 1 to 10 of 19
Thread: Switched live for aftermarket stereo
    Jan 2010
    Liverpool
    Default Switched live for aftermarket stereo
    I fitted my Alpine 9861ri today and have found the audioleads wiring doesn't have a switched live. The stereo just stays on when the ignition is turned off and key removed...
    Is there any way to get the stereo working the way the standard fit units do? (On and off with ignition and also being able to turn on when the key is out).
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You need to swap the red/yellow wire in the stereos wiring loom
    Jan 2010
    Liverpool
    I have done. Didn't do a thing.
    I'm sure I remember there not being a switched live on the 'C' when using adapter leads for aftermarket stereos.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i think on the later full canbus cars you need a converter ...but im not shure ...i konw when the corsa d has the factory fit sat nav unit (aftermarket one) they use a canbus adapter the give it a live and switch feed ..these have been faulty from the factory and we have been changeing a few .
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    You need to take your switched live from the lighter socket.
    It will have 3 wires...
    black = ignition live
    brown= ground
    grey/yellow = illumination.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    According to his profile its an 03 2.2dti elite which shouldn't need the cig lighter feed?
    Well mine didn't anyway
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    I agree,
    Pre October 2004 cars should have a switched live in the main 16 pin ISO connector block!!
    Be careful though, as there are two blacks...
    One for ignition live, and one for Telemute function.
    Jan 2010
    Liverpool
    Quote Originally Posted by Robsey View Post
    brown= ground
    Cheers, I'll check it out tomorrow.
    How so? I haven't checked anything with an electrical tester yet. Are you saying there should be a switched live because its an Elite?
    Jan 2010
    Liverpool
    I agree,
    Ahh, I see. The Audioleads adapter only has two 8 pin ISO plugs. It doesn't use the larger connector with the two corresponding connectors attached on the cars loom.
    I'll have a better look tomorrow. Thanks.
    Jan 2010
    Liverpool
    Another thing...I've noticed the dimmer function isn't working either, lol.
    I'll get to grips with the 'C's ways yet.
  1. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
  2. Were to take a switched live and a live from for a boost gauge
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 15:02
  3. Stereo switched live
    By andyfeeny in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 12:31
  4. What colour is the switched live to the headunit?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 21:45
  5. Parrot 3200 - Switched Live?
    By splund in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2008, 10:08
vectra c ignition live
vectra c position 1 live
vectra c switched live
https:www.vectra-c.comforumshowthread.php103057-Switched-live-for-aftermarket-stereo
Vectra c 03 dti elite stereo
aftermarket stereo not turning off Vectra C
vauxhall insignia stereo ignition wite
