Results 1 to 10 of 16
Thread: brake caliper tool
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Thumbs up brake caliper tool
    evening guys, i need to replace my rear brake pads on the veccy but i believe that the piston on the rear caliper has be wound back using a tool of some kind, does anyone know where to get this tool from and how much it might cost....my rear brakes are making a noise and on inspection there is hardly any material left on the pads....is it normal as the cars only done 27k,and i don't know if these are the original pads or not
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    rear pads wear first. I used long nosed pliers and it worked.
    Jan 2010
    Liverpool
    I used needle nose pliers to wind the piston back in.
    I undone the allen bolts to remove the pads first, then put the top allen bolt back in and swivelled the caliper into a position that revealed the piston so that I could exert some pressure on it whilst turning it.
    Be sure the loosen the bleed nipple before winding in!
    Saved me £30 odd for a wind back tool.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There is no need to loosen the bleed screw. All that means is that fluid will be ejected and the res will need topping up. Fairly pointless. I have my own tool made from a large bolt head with 2 pins welded to it and I can then spanner it round whilst applying a little pushing force with a 'G' clamp. Surprisingly it is easier to do both actions yourself as you can 'feel it'. I guess it helps to have a welder sometimes. Works just fine. My first pads went to 75,000 miles before they needed changing....
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi, iv'e just done mine and also used long nose pliers, worked fine although i found i hard to turn for quite a while before they started to retract although that may have been down to me not pressing hard enough as i turned the caliper.
    Regular Member Readster's Avatar
    Plymouth
    Halfords sell a rewind tool, you can get a VX adaptor on ebay.
    Get the proper tool matey, its easier and safer in the end.
    John
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Ste..you thought of making a few of your tool's up and selling em on here?..
    Jan 2010
    Liverpool
    Quote Originally Posted by Ste View Post
    I prefer to use the bleed nipple method rather than force the fluid the wrong way and risk damaging seals etc. I've read of possible horror stories that can occur.
    Plus, I've always done it this way.
    I wouldn't say it was pointless either. Its just my method and probably alot of others, too.
    Jan 2010
    Liverpool
    Quote Originally Posted by Mogsy007 View Post
    On another note, the fluid being ejected isn't lost from the reservoir, it is removed from the caliper as the piston is pushed back.
    This is a better method than forcing the fluid back through the system and back into the reservoir causing the level to become too high and possibly overflow.
    I know I wouldn't want brake fluid all over my master cylinder and paintwork.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    The 'joy' of doing diy or our own maintainence is that we develop ways of working or doing things that we've either been taught/shown or we've jumped in feet first and taught ourselves(my style).
    This forum has taught me different approaches which i try and follow BUT allways end up adapting somehow...maybe it's cus i'm left handed!!
  1. Caliper pistons - which tool ?
    By Sparky67 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2016, 02:11
  2. Vectra c turbo rear brake caliper tool
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2013, 18:35
  3. Brake Caliper Rewinf Tool Needed - Leeds
    By arkhan78 in forum Yorkshire (RO - vacant)
    Last Post: 3rd December 2011, 16:16
  4. Caliper rewind tool?
    By Stuarty in forum Suspension, Wheels & Brakes
    Last Post: 18th August 2008, 07:26
  5. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
