Likes Likes:  1
Results 1 to 10 of 13
Thread: Spanner for Changing Front Shocks/Springs
    Regular Member Jezzy's Avatar
    S.E
    Default Spanner for Changing Front Shocks/Springs
    When you remove the strut to replace the front shock absorbers (and/or springs), you need a 22mm spanner to undo a nut at the top whilst inserting a T50 torx bit just above it, right? The problem is that the 22mm nut is recessed, so you can't use a conventional ratchet, you need a vortex ratchet (as swan neck spanners probably won't reach down far enough). Perhaps this would do:
    http://www.halfords.com/webapp/wcs/s...egoryId_165572
    My question is, would something like this do instead, although you may need to cut the length so that you can still reach the T50 nut as well:
    http://cgi.ebay.co.uk/10-PCE-BOX-SPA...item19b9e00d55
    Apr 2009
    stockton-on-tees
    when u remove the 3 bolts would the full strut not just fall out along with that plate im going to lower my car so was thinkin of puttin molegrips on the shock n a normal socket to undo the bolt if possible???
    UK
    What about using a box spanner?
    Edit: sorry didn't see the second link above.
    Should work with a long t50 through the middle
    S.E
    Quote Originally Posted by marley View Post
    errr...the ebay link in my post above is for a box spanner.
    East Midlands
    Pity you wer'nt a bit closer or you coul'v borrowed my swan neck,all the above are no good because you need to hold the nut whilst turning the shaft or vice versa??? do you have/access to a grinder..if so buy a swan neck spanner for a few quid,and what you need to do is grind the excess steel from the back,then it will slot in nicely,much cheaper and does the job,i did this with mine and it worked a treat.
    UK
    One of these might reach through the center of a box spanner:
    http://cgi.ebay.co.uk/Stahlwille-Tor...#ht_1027wt_982
    Only problem would be the tommy bar would not go all the way through as would be blocked by the t50 bet you could grip it with mole grips or simlar.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Use a full size spark plug socket with the T or an allen key down the centre to hold the piston and use the hex of the socket to undo it.
    'Crack' it before you remove the strut from the car. Look at the 'How to' and it's comments thread - it's all good.
    http://www.vectra-c.com/forum/showthread.php?t=75303
    Jun 2006
    Kirkintilloch, Scotland
    Yes the howto referred to previously is excellent.
    I've just done my front shocks. Be aware that whilst the original shocks had a T50 the replacement Bilstein shocks had a T45 sized head.
    I used a cheap set of long torx bits from ebay (£5.99 inc post)
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370332629446
    and held the the 22mm socket with mole grips allowing the torx bit to be inserted thru' the centre of the socket.
    Whilst the spring was compressed and being fitted I did not attempt to fully tighten the top bolt, just did it enough to fully thread the bolt. Then after fitting the strut to the car jacked the suspension up from the wishbone. This compressed the spring allowing it it to be turned to fit correctly in its groove at the bottom and also removed the load from the top bolt enabling it to be easily fully threaded and then tightened.
    Regards,
    Dave
    Jan 2010
    Liverpool
    Done mine today using a box spanner and socket down the centre. Worked a treat.
    Runcorn Cheshire
    Smile Front springs replacement
    Just done all 4 springs on my vectra-c 2005, Before you do anything remove the strut cap, Get a 21mm socket and extend the rachet with a tube bar don't use any hex keys just quickly crack the nut and it will go easy, I never had the right tool to remove the nut after compressing the springs what I done was bought a 21mm socket from B&Q £2.78 used a electric grinder to grind two flat edges either side to the socket till I could fit a open end spanner, Then use the hex key to turn the shaft in the tightening rotation and not turning the socket, The nut came off fine and I used the same method to replace the nut after I had changed the spring, First side took me a few hours with grinding the socket but second side took me half a hour !
    Hope this helps !!
  11. Likes artvec liked this post
  1. Anyone near Telford fancy fitting some front shocks/springs?
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2013, 19:07
  2. Changing shocks & springs on pre-facelift C
    By Kev_A in forum Handling & Braking
    Last Post: 19th December 2007, 22:10
vauxhall vectra C replacement suspension leg
vauxhall vectra front shock absorbers top bolt thread size
how to remove front springs vectra c
vauxhall vectra front suspension strut socket
how can i modify front shock on vauxhall vectra b
what size torx key for vectra c front strut
how to change front springs on vectra c
vectra c front spring replacement
change front springs vectra c
what size spanners to take off vectra c front shocker
how to hold strut piston while tightening nut vectra
vauxhall front strut replacement
vectra c front coil spring replacement
What spanner to remove strut
what size of spanner do I use change a car shocks
change front springs vectra c v6 35mm
how to remove top nut vectra c struts
spanner for suspension on insignia
removing the strut leg from vectra 3.0 v6
how to change front shocks on a Vectra 2008
vectra c suspension strut change www.vectra-c.com
vauxhall vectra strut top nut size
vectra c strut top nut size
opel vectra c top strut tools
