Results 1 to 10 of 11
Thread: EGR on a 04 Reg 2.0lt diesel
    Lincoln
    Default EGR on a 04 Reg 2.0lt diesel
    Hi All,
    I'm new on here, so any help you can give would be great!
    I've been having problems with loss of power, I've been told its the EGR by dealer, and said it will cost £500+ to fix with a new one. Can it be cleaned on this model. I've had all the rubbers replaced, so its no them.
    raylincs
    Regular Member Dazzy2006's Avatar
    Notts
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Firstly name and shame the dealer £500 + to replace an egr is a huge rip off , what indication ,s did the dealer give you to point to the egr needing to be replaced , :ie what fault codes were quoted . more often than not dealers will go for the most expensive option with the hope of making an easy profit when the fault is something cheap and easy to fix.
    Lincoln
    Quote Originally Posted by Dazzy2006 View Post
    Hi Dazzy2006
    Thanks for infor and the how 2 link, Cleaned the erg, (wasn't too dirty), but still having same problem, I rev to just over 2000 revs, then the revs go up 500 then drop back down to 2000 (this is when warm) all the time. Checked rubber pipes for splits, (vauxhall charged me £87 for changing 1 and putting it through the diagnostics). Checked and blown through the pipes. Anything else anyone can think of?
    Lincoln
    Quote Originally Posted by bobssignum View Post
    Hi bobssignum
    I'll let you know about the fault code tomorrow and I'm going to ask for the readout, see above what I've tried.
    Anyone know of someone else I can try around Lincoln, if everything I try doesn't work.
    Lincoln
    When cleaning the EGR the Manifold has a lot of black deposits
    Just thought I'd add that.
    Notts
    when my egr went i took it to special diagnostic services in newark who charged £30 to read the codes but i kept getting the spanner and limp home mode along with poor accelaration below 2000 revs but only after the car warmed up.
    I bought my replacement egr from ebay but it wasnt cheap - £220
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330403635611
    Lincoln
    Hi again all
    Took my car back to main dealer, said the EGR fault was now clear (took it off and cleaned it, like it said in How To, thanks). But now it say's I've got a fault on the MAF sensor, they have said try and find someone with similar car and swap it and try before buying a new one. So trying to find someone local. If someone has any other ideas what the problem might be.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Try cleaning the MAF sensor
    Irmscher Insignia CDTI 130
    Notts
    as above, use carb cleaner to clean the maf. 10-15 minute job
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
