Thread: Remote Central Locking
    South Wales
    Default Remote Central Locking
    Really annoying now every problem i've had on this car (that's a lot anyone who's seen my posts will know) i have fixed except this one. Basically the remote central locking randomly works when it feels like. I've triend the reset thingy where you turn it to ignition and press the lock button on the key and nothing happens (unless im doing it wrong maybe??) any other suggestions guys as its annoying me that i cant sort it !!!
    May 2008
    newcastle
    did you ever get this sorted ?, mines just started playing up like this, it's both sets of keys with mine so i don't think its the key fobs.
    Dec 2011
    Seaham
    Have you tried new batteries in the remote controls?
    May 2008
    newcastle
    yip, changed my battery tonight, still playing up, it unlocked the door then locked it ok, i then tried to unlock which it unlocked the drivers door only & stopped working. put key in ignition & syncronised it & it started working again.
    11 Post(s)
    Try putting a thin piece of card on top of the battery (or a folded up post-it note) and put the cover of the fob back on. This will help hold the battery in place - not unknown for there to be a dry joint.
    Feb 2011
    john1 - I have had the same problem for months now - decided to try and do something about it and have been told that it could be the SIM unit which is behind the steering wheel. Not a cheap option though and no way of knowing if it will cure it.
    Feb 2011
    *I meant CIM unit
    Feb 2011
    Just to update anyone who has this problem and does a search like I did to come across this thread - I had my CIM unit replaced and it cured my intermitent key fob/remote locking problem. Has worked flawlessly since it was done 6 weeks ago.
  1. remote central locking
    By mifandmif in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 23:57
  2. Remote/central locking issue with driver door
    By Archaon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2010, 08:49
  3. help remote locking
    By swvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:45
  4. remote central locking doesnt work!!!!!!
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2009, 08:32
  5. Remote Central Locking - press open just once for all doors?
    By petesaysblimey in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 08:54
