Thread: Glow Plugs 1.9 120bhp
    Motherwell Scotland
    Default Glow Plugs 1.9 120bhp
    Went about changing them this morning. First one was fairly easy, but the second!!!! and yet this looks the easiest of them all!!! Problem seems to be the socket is turning on the plug. The first came out ok with the 10mm and this seems a very snug fit. Anyway I stopped before I did any real damage. My only other thought is the socket was not sitting properly on the plug. I used the car and it was fine. Will have another go tomorrow when the engine is cold. Any advice appreciated.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    BE CAREFULL! the last thing you want is it to round off or snap off!, not unheard of !! if the socket wasnt on correctly or is not up to the job get one that is!. try it with the engine cold next time good luck.
    Motherwell Scotland
    Thanks, but engine was cold. Is 10mm the correct socket?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    yes i believe so, try a Good 10mm on another plug,.
    Motherwell Scotland
    Cheers, I will post result tomorrow.
    Sep 2009
    newcastle
    hello
    squirt loads of wd40 down the threads of the glow plugs get a knuckle/swivel joint ex piece i would do it while is warm not hot that you cannot work on it. dont do it cold things come loose easier when there is a
    bit warmth
    Sep 2009
    newcastle
    the socket is a deep socket?
    Motherwell Scotland
    I have managed to get the second plug out and left it at that. I have sent away for the proper tools to do the job on the other two as they are more difficult. From what I can see, I will need a 1/4 drive 9" extension and knuckle. I will also need an extended pair of long nose pliars (11"). A work light is also a good tool on this job. Expect to complete this Friday. I will post a new thread with a list of tools and advice.
    Motherwell Scotland
    Completed the change of glow plugs today. 1/4drive extension and 10mm deep socket did the job easily. I would also recommend the long reach pliers for this job, long screwdriver, a piece of sturdy wire and blu tac to get the last plug out! If anybody wants advice let me know.
    Hampshire
    Quote Originally Posted by st2malo View Post
    Hi
    Any chance you can get some photos for me please?
    About where are they.
    Thanks a lot.
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Glow plugs, what do you think?
    By Croxley in forum Engine & Drivetrain
    Last Post: 6th July 2011, 14:45
  3. Glow Plugs 1.9 120bhp
    By st2malo in forum Engine & Drivetrain
    Last Post: 14th February 2010, 11:16
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. Glow Plugs
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 17:31
