Thread: no power
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default no power
    Hi All,
    went to pull away from work last night had no power my foot was to the floor went on for about 9 sec. Also I have got the spanner light on which goes off after about 5mins
    Steve
    Bristol
    Vehicle : CDTI 150
    Check the vac pipes from the vacuum pump to the various diaphraghms via their respective solenoids. Also check the hoses to the turbo for splits.
    Other wise look on the forum for people in your area with Op COm or Tech 2 to get the codes read.
    Quote Originally Posted by lesj View Post
    Thanks m8 will do
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    if the light goes of after 5 secs then could be glow plugs
    Quote Originally Posted by mattv6diesel View Post
    how could I check them?
    Steve
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    touch the top of the glow plug with a live wire from the battery you should get a small but deffinate spark. one that doesn't spark is dead
    Thanks m8 will do
    Update
    The spanner light comes on when a turn the key on then goes off the now the emissions light says on. No more power loss anyone point me in the right direction. Should I clean the boost sensor if so were can I find this on a 120 8v. Photos would be good
    Thanks Steve
    Bristol
    Vehicle : CDTI 150
    Boost sensor is in roughly the same position as the CVDTI 150. Look in the How 2 section there are pics etc
    Thanks m8
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
