Results 1 to 2 of 2
Thread: vibrating knock?
    Glasgow
    Default vibrating knock?
    hi guys, i posted a while ago about some kind of knocking from my front when going over bumps etc, the noise has progressed and when i go over bumps it sounds like something is bouncing quickly against each other? its hard to explain!
    i thought maybe something in the boot was "vibrating" off something but im sure its the same place my original noise is from.
    i put it into the garage for the locknut and asked them to look at this noise, they forgot about the noise but done the wheel nut, problem is im going to blackpool tomorrow (220mile) drive each way and im a bit concerned..
    any ideas?
    Regular Member old cruiser's Avatar
    slough
    It maybe the droplinks are shot mate, but wouldn't rule out a broken spring either, would be worth having a nose underneath and visually checking the springs and the droplinks, annoying thing with the droplinks is that it can be difficult to tell if there knackered as when the car is down on it's wheels or jacked up there is tension being applied to them , so when you grasp them and try to check for play , it may appear that there isn't any, but are cheap enough to buy and would suggest changing them.
    Cheers Pete
  1. vibrating clutch
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 20:26
  2. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  3. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  4. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
