Results 1 to 10 of 18
Thread: vectra AFL
    May 2006
    Canterbury
    Default vectra AFL
    Hi looking at getting a Vectra C but I want one with Xenons/AFL what I would like to know is if headlamp washers are fitted does that mean that it has xenons too, as according to Parkers you couldn't spec headlight wash without xenons. only asking as I am going to have to travel to view the vehicles and don't want to get there and it doesn't have them.
    cheers
    Mat
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    There's a good guide to being able to find out if the headlights are AFL. I think the main bits are the different light cluster, the blue ring around the lense and yes the washers.
    May 2006
    Canterbury
    ok cheers that helps i thought that was the case but i know you can't always rely on Parkers info!
    May 2006
    Canterbury
    Ah yes the good give away is that the headlight angle adjust button is not there , its not on the car and has washers so must have AFL cool. cheers
    Leicester
    Headlamp washers on their own were only an option on the winter pack in 2002-2004. It was never offered after this time.
    All facelift Vectra's and Signums with headlamp washers will have AFL zenons, not normal zenons. Unless of course the headlamp washers were retrofitted by the owner).
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    if you looking for AFL, look for the square indicator too
    May 2006
    Canterbury
    ok cheers guys thats excellant advice should be able to spot them now. amazing how many sellers do not advertise the fact that they are on the car, guessing that they don't know that they are on there!
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    lol i got my vectra & the seller Vauxhall Network Q listed it as a standard Elite with leather & satnav
    But the extra option it has are
    AFL headlights with washers
    Bluetooth
    Sports Suspension + 18" 11 spoke wheels
    Front & rear parking sensors
    ESP+
    just keep a look out for the all the options there are more
    There are quite a lot of fully loaded vecs out there, more so than base spec ones. The only time it's hard to find a good deal with a lot of options is when you want a Signum rather than a Vectra.
    Quote Originally Posted by maurauth View Post
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
