Results 1 to 10 of 22
Thread: Perfect gear change in a 1.9 cdti(150)
    ashford kent
    Default Perfect gear change in a 1.9 cdti(150)
    Hi all,
    I was wondering at what revs the perfect gear change would be in race? i have a 1.9cdti(150) sri 6speed and as this is my first diesel powered car so need a little help lol?
    cheers
    Regular Member mr.ian's Avatar
    Ayrshire
    Oh dear.
    Are you old enough to drive? "lol"
    ashford kent
    do you know the perfect change?
    cheers
    sorry about the lol
    Ayrshire
    Quote Originally Posted by jay_c2010 View Post
    cheers
    sorry about the lol
    Mine's an automatic. I drive for work not for racing.
    ashford kent
    hmmmm i don think that will help then....
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    keep it floored while you dip the clutch and change gears fast....it will be nice and quick.
    i will give the flywheel a month tho lol
    Regular Member Slick's Avatar
    BEVERLEY
    sorry but if you bought the diesel for "racing" you made one BIG mistake!!!!!!
    diesel arent meant to be raced fast or anything there meant to get you from a to b minimal trouble but still have the grunt to over take at say 50 to 70
    if you wanted a racer you should have bought a 2 litre turbo petrol or 3.2 v6 or even the 2.8t v6 not the cdti
    i spent approximately 3 grand on my last diesel car which i took on the track plenty of times loads of power coming out the corners but petrols left me for dead on the long straights
    if you wanted a fast racer should have stuck with a petrol simply diesels arent racer
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    Quote Originally Posted by Slick View Post
    Audi Le Mans car?
    JK
    BEVERLEY
    i meant a normal road car not a ****** race built car altho i wouldnt mind the engine in a vectra lol hmmmm V10 diesel vectra YES PLEASE
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To try to answer the question.
    The only way in which you can answer this is to have a full load torque curve for your and to know the gear ratios.
    From these 2 things you can decide where the torque out of gearbox (theoretical, ignoring transmission losses to make to easy) in the next gear up (at the new engine speed) is equal to that in the current gear. As the torque if you left it in that gear would begine to drop (at the top of the rev range) and the torque in the next gear up would either be climbing or at least level.
    Generally for diesels this point is just before rated speed.
    Here is a chart showing torque out of gears into final drive across the rev range for a 'modern diesel car' - I can't tell you where it is from....
    Gear ratios are
    Gear 1st 2nd 3rd 4th 5th
    Ratio 3.5 2.7 1.8 1 0.87
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. For Sale: Top Gear Best Bits - 4 BOOK SET (Perfect Xmas Gift)
    By Vaux-Man-G in forum General items for sale
    Last Post: 11th December 2011, 15:29
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. Veccy 120 CDTi Poor Gear change
    By ali06 in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 22:08
  5. Best gear change point - 150 CDti
    By FinestJammy1 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:29
