Results 1 to 10 of 16
Thread: 2.2dti help needed
    Regular Member mooney's Avatar
    North west
    Trim : VXR
    Engine : 2.8 v6 turbo
    Year : 06
    Default 2.2dti help needed
    when driving along if the revs go above 2.5k in 4th or 5th the spanner light comes up and it looses all power, pain in the arse if your joining a motorway or overtaking someone,
    if i turn the ignition off and back on the service light goes off and everything as long as i keep it below 2.5k
    its under warranty but until the engine management light comes on and stays on they don't know what it is and cant fix it,
    anyone got any ideas?
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    hello mate could be one of a few things but before you start jumping to great expense three things to do
    1.clean the boost sensor
    2. clean the EGR valve
    3. check the hoses for air loss
    Just use the search bar at the top and you will find plenty how2's and guides
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    To elaborate on shauns answer check all of the small vacuum pipes (thin plastic pipes with rubber ends, emphasis on the rubber ends as they are normally the bit to split)
    Also check the large boost hoses, there is one that comes from the turbo down to the intercooler and one from the intercooler up to the inlet pipe. These pipes start to rot with the oil vapour from the turbo (they are pretty thin walled)
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The damn thing went into limp mode about 1000 times today on the motorway. On-off-on-off...even just a flicker of the spanner light caused power loss. OP-COM showed boost sensor fault code so cleaned the sensor and all is well
    Jun 2009
    Newcastle
    Can you tell John is a million times more technical than me?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by shaun260589 View Post
    It's called experience with the DTi misery lol
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Celes View Post
    Yep thats me DTi owned lol
    I always forgive it though as I love the dti engine
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Love it too! Goes on forever and likes it rough ............... lol
    North west
    Trim : VXR
    Year : 06
    thanks for the advice guys
    had a quick look today and here's the engine without the cover
    is this the egr? (to the right of the dipstick) and do i just disconnect the 2 pipes going into it?
    i found 2 split end pieces marked with yellow electrical tape, anyone know part number or what there called?
    one of the pipes went to the black thing with a plunger type thing,
    and the other went, the black pipe
    can someone please circle the boost sensor please
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    The two pipes you have wrapped in yellow tape are the vacumm hoses you just need to go to a motor factors and buy a length of vacumm hose and cut it to size.
    Attachment 29296
    Boost sensor is circled in yellow you have to disconnect the plug and then undo torx bolt ( being carefull not to drop it) then take out sensor and if is black (sooted up ) then get some wd40 and a small paintbrush and clean very carefully you are looking for a little bulb that looks like a grain of rice HTH
  1. 2003 2.2dti oil change help needed
    By Allenglish2003 in forum Engine & Drivetrain
    Last Post: 12th August 2012, 20:45
  2. 2.2dti
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 16:33
  3. Max bhp 2.2DTi
    By JWBakkum in forum Diesel Engine related
    Last Post: 5th November 2010, 18:48
  4. What is a decat? 2.2dti advice needed....!
    By nim-nim in forum Diesel Engine related
    Last Post: 9th July 2010, 23:11
  5. Help needed from 2.2dti owners please
    By JudgeApocalypse in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 11:11
