Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Poxy HIDs !!!! Grrrrrrrr
    Regular Member Matty777's Avatar
    Jan 2010
    Nr Maidstone
    Default Poxy HIDs !!!! Grrrrrrrr
    Well having given the HIDs I got from HIDs Direct a "glowing" review, I am probably going to retract it!!
    These were only fitted last Saturday (thanks to Soulman, Plasma, SignumBob) and they worked great, no issues.
    Now the flipping O/S one has decided to start acting up!! I noticed this today, when I put my lights on at home only the N/S fired up and I got a bulb out warning. Turned them off and back on again and it "fired up" and worked fine.
    This evening same thing, but took 3 or 4 off/ons before it worked but when it came on it stayed on with no faults, flickers etc.
    Got home, and now no matter how many times you off/on them, the O/S refuse to turn on.
    This doesn't seem a regular fault, it seems that it's not "firing" properly as I understand they have to so some major arcing/power thang to fire them up.
    ANyone with them, can you also confirm that when the lights first get turned on they flick up really intensly bright on first turn on, then go much dimmer then build up to full brightness, is that normal to be so bright when firing up. (well I only have one now!!)
    Any help?? If I was mechanically minded I'd take my bumber off and take them off and demand a refund. May just do that and just get some plain old Nightbreakers instead
    (Just wondering if I can get at them without taking that blooming great bumper off, Facelift ones are sooooo heavy and awkward!
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    After working fine for a couple of weeks (apart from the flickering caused by a faulty ballast) my nearside bulb kept going out and throwing up the bulb out warning on the dash, if I turned the lights off and back on everything was fine for about 5 mins then same would happen again. Fitted a canceller eventually to that side and since then no more problems.
    Jan 2010
    Nr Maidstone
    I have the cancellers, so you reckon even though they didn't need them at the start, sometimes a fault develops preventing them firing up. The cancellers should sort this out?
    Hopefully, i can get to the wiring and just plug them in line.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its the prefacelifts that tend to need cancellers. I've seen the Jam kits work on facelifts then get sold to a pre facelift owner who then needs cancellers. If I turn on my Hids and then turn on the ignition then one bulb doesn't work on mine. I always have to start the car then turn the lights on. As yes they really pop on bright, dim then come up to temp.
    11 Post(s)
    Because of a voltage drop maybe?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    That used to happen on my vec b, if i fired up the lights before cranking the engine then one of the lights would go out, its due to a voltage drop, think the battery drops to about 9-10v volts during cranking which isnt enough really to run the HID's.
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Same on the ones i fitted in mine Matt.. voltage thing i found.. hold the revs at 1500-2000 and then switch on
    What a performance for a little extra light ....... I don't have them by the way ......
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've had a set from HIDs4U fitted for over 2 years without a problem - pre f/l without cancellers, although I believe cancellers are an integral component with these.
    Mine always come on bright, dim then build up regardless of when or how I switch them on
    Jan 2010
    Nr Maidstone
    Tried revving then switching on so that the volts were high, but alas no o/s at all now
    At work for next 5 days, and lates too.....need lights arrgghghh! No time for a bumper off jobbie!
  1. help p2279 grrrrrrrr
    By gus evo in forum Engine & Drivetrain
    Last Post: 12th July 2012, 08:21
  2. H.I.D`s Grrrrrrrr
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 18:58
  3. Grrrrrrrr - Police Mechanics - Grrrrrrrr
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2008, 19:23
  4. What a Poxy day.
    By AndrewTi in forum The 'Off Topic' room
    Last Post: 7th July 2008, 21:10
  5. Grrrrrrrr - RANT - Grrrrrrrrr
    By Angel Boy in forum General Chat
    Last Post: 6th April 2006, 23:46
