Thread: front end judder
    Regular Member sla002's Avatar
    hayes, middlesex
    Default front end judder
    hi guys,
    i'm getting a shake through the steering it starts at about 65, i've had all the wheels balanced, checked all the ball joints and bushs and can't find any play, have also swopped all the wheels around, but its still there.
    any ideas.
    have been told it mit be the brake discs, i can feel a slight pulse through the pedal, but have never heard of the wheels shaking through worped discs.
    Regular Member OSSY's Avatar
    Apr 2009
    This is the same as what's happening to my vectra. When your stopping in your car and snowing down just about to stop and have a light grip of your wheel do your front wheels seem to have a mind of their own?
    Hope that makes sense?
    When i brake my wheels wobble and turn off to one side - could be the left, could be the right... no set pattern. Its not always been like this and its getting worse. Steering arms? is there such a thing?
    hayes, middlesex
    mine only does it at speed when you come to a stop it seems smooth.
    sounds like steering arms/track rods or maybe track rod ends or lower ball joints, worst case even play in the steering rack. best thing to do is jack it up and pull the wheels around to see if you can find any play.
    had to do my track rods a few weeks ago. but the car did stop in a straight line.
    had a good look today and the drop links seem a bit lose, but again not sure if this would make the steering wobble. not getting any knocking either which i thought you got from worn drop links.
    Edinburgh
    have you had your alignment/tracking checked?
    West
    Inner track rods?
    hayes, middlesex
    tracking done and inner track rods changed, both within the last month.
    Northampton, UK
    Maybe its the tyres? I found when I had XL tyres from a Vectra estate on my Signum, it followed the uneven road more.
  1. Judder and eml
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 07:41
  2. Judder at 50 to 60
    By Faz2726 in forum Troubleshooting
    Last Post: 17th January 2012, 00:00
  3. judder
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 28th December 2011, 14:41
  4. Judder in 1st
    By jongiddings in forum Engine & Drivetrain
    Last Post: 19th March 2011, 17:04
  5. judder
    By twaiter in forum Engine & Drivetrain
    Last Post: 14th July 2009, 21:26
vectra c front suspension judder
