Thread: spares day
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Default spares day
    whos going?
    and is anyone taking tech 2 with them i would like to borrow if poss to try and get to the bottom of the problems with our siggy
    thanks
    WGAF#5
    are you still experiencing boost issues??
    CORNWALL
    changed both sensors and still drives the same
    if you drive it hard it seems ok but you poodle around normal driving cruising along the motorway it cuts out like it always has done i think its a bad map fom bsr personally
    or jems driving but i cant say that cos she will slap me
    WGAF#5
    i'm still having problems too - ive been in contact with turbo technics at northampton - here's a response i have had from Pete Petch as i suspected it might be the wastgate creeping - as the spring was getting weak and the extra boost was causing the creep..
    Hi Dez,
    From what you have told me it sounds like you have more of a map problem rather than "boost creep". Theres 2 ways to get round this. Firstly, have the map checked by a specialist ( Courtenay Sport - Jon 01692 404313 ) and see weather the parameters for the boost map are correct. Alternatively lengthen the rod on the actuator so it reduces the boost level. What you will probably find is that when the air temp is cold, you will see the soft fault log more than when the day is warmer. Ie in the summer you probably wont see this problem. Really doesn't sound like a problem with the turbo to me.
    soo..... i might be playing with the actuator rod
    hth both of you
    regards
    Dez
    CORNWALL
    Too right Mr! And it's not my driving. Where you Dez? Fancy trying ours too, not that I'm saying Matt's mechanical skills aren't up to it or anything
    WGAF#5
    i'm in not so sunny Suffolk - so about 6-7 hours from you
    mine drove ok having replaced the solenoids for about 150 miles before the soft fault reoccurred = its just annoying as mine will mostly occur when im in the middle of an overtake and this is normall on "A of B roads" so not the best times really
    i've got commitments over the weekend (including a full day Sunday playing with the new Peugeot RCZ) so at some stage i will have a play and i'll do a how2 for you
    it shouldnt be too difficult (famous last words) touch wood
    i'll be in touch
    regards
    Dez
    Aug 2009
    York
    I'm off, I'll see you there!
    CORNWALL
    You setting off now!? You may aswell just carry on down Sunday hadn't you and stay at ours as I'm now paying for your petrol!
  1. Anyone going to spares day??
    By mitch1965 in forum The 'Off Topic' room
    Last Post: 11th March 2009, 20:36
  2. Spares day
    By vecgsiboy in forum General Chat
    Last Post: 6th March 2009, 22:13
  3. Spares Day
    By Matt&Jemz in forum General Chat
    Last Post: 6th March 2009, 21:48
  4. 24/7 spares anyone used them?
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2008, 14:27
  5. spares
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2008, 00:25
