Thread: wheel sizes + speedo
    Regular Member steve.s's Avatar
    Mar 2007
    spalding, linc's
    Default wheel sizes + speedo
    this has probably been asked befor, sorry in advance.
    if i got the 18" vxr replicas from lmf or 19" vxr wheels, what size tyres need to go on the 18's and would the said wheels 18/19 throw the speedo out after going from 17's
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Leicester
    Easy one to answer.
    If your running 215 50 17" tyres,
    225 45 18" and 235 35 19" tyres are in the same group on tech 2.
    The 18" VXR replicas are 8" wide, so your best bet would be 235 40 18" like the VXR. You will also be OK with this size without upsetting anything.
    Avoid 225 40 18" tyres, as this will slightly throw out your speedo. There will not be an issue technically but they were never an official size for Vectra C.
    Mar 2007
    spalding, linc's
    thanks for your help guys, what do you mean by the same group on tech 2 maverick
    Mar 2007
    spalding, linc's
    would 19's kill accelaration much
    Regular Member DaveW555's Avatar
    Cannock
    I dont think any would throw your speedo out as its done by the abs sensors not by a sensor in the gearbox
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Quote Originally Posted by steve.s View Post
    Make no diffrence at all really.
    Regular Member malk's Avatar
    suffolk
    Quote Originally Posted by Maverick View Post
    Easy one to answer.
    Interestingly (or not!) I have 225 40Z R18 92 W tyres on my V6 SRi. Now trying to find replacement wheel and tyre set.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Forgive me for being a bit ffikk. I'm not used to changing wheel sizes....But how will putting a wider wheel on your car throw your speedo out? Ok I understand that if you put a 18" wheel on (Changing from 17s) you need to reduce the size of the wall on your tyre to keep the circumference the same How Does width effect it?
    Mileage : 000
    A tyre has a thing called aspect ratio. that is the "height of the tyre from the ground to the rim "ie" 215(tyre width) 50 (aspec tratio) 17 (wheel diamiter).
    Now the aspect ratio is the percentage of the tyre width. that is if the tyre is 215 wide then the aspect ratio is50% of that=107.5.
    So if you put a tyre with say 225 wide the aspect ratio of 50. the tyre would be 112.5 from the ground to the rim. so the overall dia would make the wheel cover a larger distance fo one rev of the wheel, so throwing the speedo out a little.
    Hope this makes sence now.
  1. Wheel sizes
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 02:09
  2. Wheel Sizes..?
    By pjames.79 in forum Styling
    Last Post: 5th March 2008, 16:09
  3. Wheel sizes
    By carlos_superstar in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 17:13
  4. wheel sizes
    By customaccent in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2007, 23:46
  5. Wheel sizes
    By 24vElite in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2005, 13:15
