Thread: 3.0V6 cdti turbo failure - any How2 replace advice?
    France
    Default 3.0V6 cdti turbo failure - any How2 replace advice?
    Well, after replacing suction control valves, rear suspension control arms, in the last few months, I had the turbo fail big time on Monday (approx 110k miles FVSH with synthetic oil). On accelerating, engine coughed, puffed out some black smoke and then gave a whirring noise from the left underbonnet area. No light came on and I managed to drive the 1 mile home. Started the next day and whirring noise still there. Drove out and up a slight hill and then noticed a WW3! white/grey smoke screen from behind. The engine lost power but still no light. Eek! switched off and got a friend to trailer it back home.
    Removed rubber hose to turbo to check for play in the shaft as advised by specialist - the whole impeller/shaft is completely loose and waggling around!
    Local Opel dealer has quoted 3200 euros (~£2800) to replace the turbo, gaskets, and program the "Calculateur" which I assume is use of Tech 2.
    I'm not prepared to pay that so will get a new turbo for around £700 and attempt to fit myself with the help of a couple of knowledgable friends.
    Anyone have any advice on how to remove and replace a vectra 3.0 v6 diesel turbo, anything special to watch out for? I don't really want to start the engine again before replacing but do want to replace the oil and filter. Will it be ok to do this cold? I also read another post on here (GSi I think) that talked of the need to prime the new turbo and clean the banjo filter but I don't know if this applies to the 3.0L. Also would it need to be Tech 2ed or calibrated in any way?
    This car is fast becoming the best and WORST car I have ever owned.
    Oct 2009
    rhyl
    not sure on removal but should be able to get it reconditiond for about £300 never seen thread with a turbo go on the v6
    Bristol
    its not to bad to remove. I done mine myself . About 2 hours most to remove.
    France
    Did the replacement require any tech2?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by littlejohn View Post
    No
v6 cdti suction control valves site:www.vectra-c.com
how to remove turbo on a 3.0 vectra diesel
replacment turbo on a 3.0 vectra diesel
3.0 cdti start badly
fixing a 2008 vectra 3.0 cdti turbo
replacing turbo control on vectra 3.0 v6
replacing vauxhall vectra v6 turbo
2009 3.0 v6 vectra turbo failure
