Thread: Passanger window
    Dublin
    Default Passanger window
    hi all.my passanger window will not work using the button on the passanger door but will work if i use the button on the drivers side??any solutions??thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Use the drivers door switch
    Sorry only kidding, have a look in the How2 section as i'm sure there is a how2 for cleaning the contacts on window switches
    Found it for ya http://www.vectra-c.com/forum/showthread.php?t=92625
    Dublin
    cheers pal.i just bought one yesterday and there seems to be a few little problems.the fans in the car that blow the air out wont work unless its on the highest which is 4 i think.any suggestions???and it also automatically comes on when u put the front de-mister on.it comes on full blast even if its a t 0????
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The resistor for the heater motor is knackered mate, quite a common fault on the vecs. The windscreen button is supposed to direct all air to the windscreen of full blast so it is working as its meant to
    Dublin
    thanks mate and does this cost much???
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    They are about 20 quid from the dealer, also you may find that the passenger side footwell of your car is wet. If the drain hole under the windscreen blocks up water comes in through the cabin filter. This is what destroys the resistor
    Dublin
    alright mate thanks ill check that aswell.are those resisters hard to fit myself??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    http://www.vectra-c.com/forum/showpo...1&postcount=22
    Glovebox has to come out but its pretty straight forward
    VX part number is 9180020
    Not sure what the opel number is though sorry
  1. Passanger door handle
    By LANCE1 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 14:39
  2. Water in passanger footwell and it not the suttle tray.???
    By dannydoncaster in forum Bodywork & Interior
    Last Post: 17th June 2012, 06:37
  3. passanger seat
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 4th August 2011, 11:55
