Thread: Rear Door Card removal
    Regular Member yadziyad's Avatar
    London
    Default Rear Door Card removal
    hi guys, i need to change the rear speakers and just need to know how you remove the rear door card i am having trouble with removing the manual window winder.
    thanks in advance.
    Full Member paul.sessions's Avatar
    leighton buzzard
    have a look at this how 2 fella tell you all you need to know..:hth:
    http://www.vectra-c.com/forum/showth...t=cloth+winder
    The winder is held on with a circlip - the way I've read best and found to work is to get a pievce of cloth and catch it on one end of the circlip, then wrap the other cloth round till it catches on the other end of the it and pull it off. In effect you need to pull both ends of the clip at the same time, and the cloth allows you to do this...
    London
    cheers guys will do it in the morning
  1. door card removal
    By dave_veccy_c in forum Bodywork & Interior
    Last Post: 2nd April 2010, 10:37
  2. Rear Door Card Removal How To??
    By AirCooledHeaven in forum Bodywork & Interior
    Last Post: 8th September 2008, 09:29
  3. 05 sri door card removal same as 04???
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2007, 13:35
  4. Door Card Removal
    By Jamie in forum Bodywork & Interior
    Last Post: 30th May 2006, 18:33
  5. rear door card removal
    By Nickzx6r in forum Bodywork & Interior
    Last Post: 1st May 2006, 09:34
vectra c rear door card removal
how to remove rear door card in 2006 vectra
how to remove vectra c rear door card
vectra c rear door multiplug removal
vectra 2006 door card removal
vauxhall vectra 2007 rear door card removal
