Thread: rear suspension bush
    North Wales / Leeds / South France
    confused rear suspension bush
    car has been in for some work and come out with a couple of advisory's:
    1 Nearside and offside trear outer bearing worn, allowing the inside of the rears tyres to wear.
    are these part of the trailing arm or something else.
    2 Rear shockers misting,
    will be on the phone to LMF as these are less than a year old Bilstiens.
    3 Nearside and offside stering rack slight play.
    cananybody show some light on number 1
    Thanks Phil
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds very much like the upper control arms are knackered, also maybe worth getting the geometry set up right.
    sounds like they are as regular to replace as the vec b rose bushes
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Very easy to check them, with the car on the ground grab a hold of the top of the wheel and give a sharp pull. You will hear a knocking noise
    thanks J R seen what i think i need on fleabay, will check price at local motor Factor tomorrow.
  1. Rear suspension bush (lower) How do I change it?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 2nd December 2016, 12:41
  2. Rear suspension bush tools ?
    By JagRigger in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2012, 20:23
  3. 2005 upper, outer, rear suspension rose bush
    By kbs in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2012, 20:21
  4. Help - Rear suspension bush
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2009, 21:24
  5. Suspension bush
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2005, 11:19
