Results 1 to 10 of 27
Thread: help p0111
    newcastle
    Default help p0111
    hi got vectra c sri 150 56 plate with 60000 on clock orange engine symbol on which exhaust gases the car drives but has no power takes ages to get up speed and is using more petrol took car to garage and they said it is loss of induction fault code came up p0111 Intake Air Temperature Circuit Range/Performance Problem but couldnt see any split in hoses wanted another 46 pound to look round car more any 1 have any clues where it will be will this be the erg needing cleaned or a more serious problem
    Oct 2009
    rhyl
    it means your enigne is about to blow up mate
    only joking sorry i could not resist will do a search now mate
    Oct 2009
    rhyl
    p0111 air intake take temprature sensor
    newcastle
    thanks where will it be car novice but skint so having to do myself garage is last option
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's a problem with the temp sensor in the MAF (the plastic tube with a multiplug that comes from the airbox)
    Possibly needing a new one
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    air intake sensor is part of mass air flow meter if po100 is not stored problem is more likely to be something else like egr valve stuck
    newcastle
    will it be worth taking egr valve out and cleaning it reading other post bout lack of power below 3000 revs when pulling away before power kicks in or am goin to vx garage to be shagged up arse
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    If you know what your doing give it a clean, it won't hurt
    newcastle
    ne idea mate but im skint so goin to try how much do you think vx would charge to fit sensor
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The sensor is part of the MAF assembly and anyone with a screw driver can fit it.
    Simply disconnect the multi plug and release the 2 large jubliee clips and remove from the duct between air filter and engine intake. It should take 5 minutes, and that includes opening the bonnet.
    TBH I can't really see how a malfunctioning / dirty EGR valve could affect the temperature sensor range. It MAY actually just be that the multiplug contacts need a clean or are wet. Worth a look see and won't cost a penny to check.
