Thread: Signum 2.2 DTi cutting out/ loss of power
    Regular Member muzmayhem's Avatar
    Jan 2010
    North Angus, Scotland
    Default Signum 2.2 DTi cutting out/ loss of power
    Suprise suprise!! After only 2 weeks of owning a Signum 2.2DTi it's booked into the garage for Monday. Keeps 'missing beats' at speed and I've had it cutting out/ loss of power when pulling out at junctions. The final straw was last night when coming home from work. Sitting in the central resevation of the dual carrageway, pulled out onto the road then it splutterers and stopped accross both lanes! Panicked and hit the throttle and she slowly came to life again, just making it accross the road before the traffic flew past. Thank god the kids were not in there with me!
    Never noticed the engine/spanner light come on though.
    Not even going to drive it the rest of the week. Guess this will be the start of my bank account being emptied.
    Jan 2010
    Eek
    Heard back from the garage today. Said it needs a new throttle body. Hope this does the trick. Should I get the EGR cleaned out as well?
    Regular Member eaglepva's Avatar
    Up North
    mine does the same thing mate. How much for a new throtle body? i gave the EGR after recomendations from vectra-c forum and the AA a good clean soaked in acetone overnight and its not done it since (touch wood)
    Jan 2010
    Car has a 3 month warranty on it, thank god! Kinda lost a wee bit of confidence with the car. If it so much as coughs next week it's going straight back! Think I'll get a mate to do the EGR cause I'm hopeless under the bonnet.
    Jan 2010
    warwickshire
    hi had the same problem as you with mine.... replaced the upper induction manifold on the exhaust.... looks like a throttle body.... it carbons up..... cost £260.00 fitted and its done the trick.... seems to be a common problem with the dti 2.2 ......
    Up North
    is that the bit above the EGR valve
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Quote Originally Posted by thrasha View Post
    ...seems to be a common problem with the dti 2.2 ......
    Mine had the same problem. A new throttle body fixed the issue.
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Mine done the same and Vauxhall fixed it for free.
    Boost Sensor needed cleaning.
    Take off the top plastic cover and 1 torx screw holds the sensor on located at right hand side front of head.
    There is a thread on here somewhere with pictures about how to clean it.
    Fixed my problem and it was loosing power and spanner light coming on when stopping at junctions, traffic lights etc.
  1. Signum 3.0 power loss
    By bigbazk in forum Y & Z30DT Specific
    Last Post: 15th September 2012, 14:28
  2. 3.0 V6 CDTI Cutting Out/Power Loss
    By jagz21 in forum Y & Z30DT Specific
    Last Post: 21st September 2011, 15:28
  3. problem with signum 2.0 dti loss of power
    By unhappy of wales in forum Troubleshooting
    Last Post: 10th July 2011, 21:38
  4. loss of power signum
    By marcb in forum Engine & Drivetrain
    Last Post: 20th October 2009, 23:11
  5. 2.2 Direct Signum Petrol - Loss of power
    By Binksy2.2Direct in forum Engine & Drivetrain
    Last Post: 9th July 2009, 00:33
vectra c 2.2 dti starts and cuts out
