on google they bring similar faults suggesting bank 1 and 2 ie both sensors but my dads pc is windows 7 and this disc is just crashing the pc
my limited cash has run out after spending 1400 on the car lol bread and water for me til the end of the year lol
im finding the same fault for both codes mate will check later but best i can do now,your very unlucky if both sensors have gone,not sure the price of an 02 sensor but the egt exhaust gas temprature sensor was £107 for a little sensor and a foot of wire its inbetween booth 02 sensors,but when i did the test it brought that code up and i bought the part and all was fixed i thank the guy who found out about the brake accel trick
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
Its the same sensor, looks like it has packed in
thanks both.....wheres best to price up a new bank 1 sensor 2 thingy?
they vauxhall only or is there a cheapy similar kind?
when my sensor failed i dont think i lost any power but your best getting it done mate have a little cry but im not sure how you tell which sensor it is pre cat or post cat
oh and by the way....dya know if this is an MOT fail? its due the end of the month (****** typical eh)
you need an 02 sensor,but the problem is you have 1 before the cat near the turbo and 1 after the cat you might be worth getting a price on fitting as it should only take 30 mins max even if its a tight 1
unless your emissions are effected but i dont think it will fail the m.o.t as the ecu puts the car into a pre set mode
