Results 1 to 2 of 2
Thread: Coolant Leak - Aussie Holden Vectra C z22se 2.2l Hatch
    Nov 2009
    Adelaide Australia
    Default Coolant Leak - Aussie Holden Vectra C z22se 2.2l Hatch
    Hi, I have a 2003 Holden Vectra C z22se 2.2l Hatch - leaking coolant from the engine (between the firewall and engine) - I have done some reading on Aussie Opel forums and on Vectra B models at least, it would seem to be the heater tap valve - I have rung a (gulp) Holden dealer and Motor Traders here in Adelaide and they were both unable to find a heater tap valve part reference for this engine/model.
    My question is - does this model/engine have a heater tap valve, if so, is it the likely cause of the leak in your measured opinions? I am losing approx 1.5l of fluid each time I run the car for more than 30mins (on a 30 degree + day).
    The picture below is of the heater tap valve for a different 4 cylinder Vectra motor (Holden Vectra - JR JS - 6/1997-1998-1999-2000-2001-2002 - Engines - 2.0L, 2.2L, 2.5L, 2.6L - C20SE, C20SEL, X25E, Y26E)
    Blantyre
    I am pretty sure the 2.2 direct has one of these on the bottom LHS of the RAD, reason i know is i used it to drain the fluid out and also advised by Sean 2.2direct when i cleaned the EGR
    ( If its the same item )
  1. 2.2 coolant leak
    By jrh1 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2012, 18:07
  2. holden badged black hatch in scunthorpe
    By bembo449 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 4th February 2012, 20:10
  3. V6 coolant leak
    By Critch in forum Engine & Drivetrain
    Last Post: 5th May 2011, 20:58
  4. Coolant leak
    By DNS in forum Engine & Drivetrain
    Last Post: 7th January 2010, 13:10
  5. 2.0T Coolant leak
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 22:53
Holden vectra cd 2001 2.2 heater tap valve leak
opel vectra heater tap valve leaking
holden vectra 2003 coolant leaking
z22se heaterr valve
holden vectra 2001 coolant leak
