Thread: Servicing 2.2 Direct
    Derby
    Default Servicing 2.2 Direct
    Hi.
    Just wondered if anyone had a service plan for the 2.2Direct SRI. I have recently bought one and it is due a service! Got all the filters, oil etc for it.
    Are most of the parts easily removed/accessible on this engine?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Hi mate welcome to the site
    Yeah the only real problem is the oil filter if you dont have the correct tool.
    I used Mole grips but its not hard to do at all
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    20k or 1 year. small then large, small then large. oil filter is the most fidley a 32mm plastic housing under the inlet manifold on the right sump is just a 15mm bolt. air and pollen is simple pollen doesn't req any tools. fuel filter is drivers side of the tank has special clips
    11 Post(s)
    Info is available on Vauxhall's website:
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    Blantyre
    Quote Originally Posted by mattv6diesel View Post
    Yeah and the fuel filter is a flippin pain to do, long nose pliers with a bent tip is the way i went, after realising i had to push both sides of the clip in
    Derby
    Brilliant, thanks for all you help!
  1. Servicing the vec...
    By Admishere in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 15:03
  2. Servicing
    By DuncanM2009 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th February 2011, 23:27
  3. Servicing my vec c ???
    By crazy-dee in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2009, 15:27
  4. Servicing My car
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 12:45
  5. Servicing
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2007, 12:25
